[MapServer-users] Tutorials for creating time dimension images and good web frontends for dynamically changing map projects?
Sven Schroeter schroeter at netgis.de
Fri Oct 14 02:15:37 PDT 2022
here are some quick ideas which tools could be interesting in this context:
If you want to start with python (or php) then I would think about using
mapserver based on mapscript.
https://mapserver.org/mapscript/index.html
You can use ogr2ogr to easily create shapefiles.
For meteorological analysis the time parameter for WMS services is useful.
For leaflet there is a plugin:
https://github.com/socib/Leaflet.TimeDimension
Happy mapserving
Sven
Am 14.10.2022 um 08:39 schrieb Stefan Gofferje:
> Good morning all!
> After the relative ease of my first mapserver project, I'm now
> motivated and keen on getting another project running.
> Since about a year (plus minnus), I'm every day checking for Sentinel
> I and II data covering the area where I live. If there is anything, I
> download the data and run some scripts which do automatic processing
> and generating of composites, like SAR VV/VH or NDVI, NDCI, etc.
> The ready images are then posted to a Telegram channel.
> At the moment, there's still a number of manual steps (search data,
> decide what to download, trigger download, trigger processing and
> trigger Telegram push) and the existing scripts are Bash scripts
> calling GDAL tools.
> My first step now is to learn Python and move everything from Bash to
> Python and automate it, ideally so far that the whole process can run
> in a Docker container as a cron job.
> Then I was thinking, instead of pushing images to Telegram, I could
> use mapserver to serve the images to some web frontend. The map files
> are very easily created programmatically, so that should be easy. I'm
> missing a few things for that, though:
> While going through mapserver's docs, I noticed that it can handle
> time dimensions for imagery. That sounds like something worth
> exploring. The docs describe the use of a shape file but
> unfortunately, I have no clue how to to *create* that programmatically.
> Regarding the frontend, I could just put up a single page leaflet app.
> That would be easy enough. But I'm wondering if there's already some
> cool solutions out there.
> So, If anybody has a link or pointer for me on the programmatic
> creation of shape files for time-indexed imagery and/or interesting
> web frontend projects, I would be very grateful!
> -Stefan
More information about the MapServer-users mailing list
