[MapServer-users] Solved: WMS: Not all features show, depending on how I zoom and pan
Antonis Christofides antonis at antonischristofides.com
Sat Oct 29 00:59:41 PDT 2022
Thanks Scott and Seth for the help.
You might not remember, because it was several weeks ago, but I had several GML
source files in EPSG:2100 (Greek grid), and when MapServer was responding to a
WMS request requesting the data in EPSG:3857 (or 4326), several features would
be missing.
I converted the data files to shapefiles to see what would happen, and there was
no improvement. In fact I think it was slightly worse.
Then I upgraded MapServer to 8.0.0 (from 7.6.2) and the problem disappeared. I
used 8.0.0 and not 7.6.4 because I didn't want to compile it and I installed it
from Debian bullseye backports, and backports only has 8.0.0. So I don't know if
the problem exists in 7.6.4.
Regards,
Antonis
On 02/10/2022 17.53, Scott wrote:
> It would be interesting if you could change your 'irrigation-network.gml' into
> a different format, say .shp, something like:
> ogr2ogr irrigation-network.shp irrigation-network.gml
> Then try that as a data source in your layer and see if your results differ.
> This would might help us distinguish between a driver issue and a mapserver
> issue.
> On 10/2/22 04:51, Antonis Christofides wrote:
>> Hello Seth,
>> Thanks for replying. I experimented and found out there's no difference if I
>> use something minimal such as what you suggested. What does make a difference
>> is the CRS: if I tell QGIS to use EPSG:2100 (Greek grid—the CRS the data
>> files use), then everything works fine. If I use 4326 or 3857, then the
>> problem appears. Therefore it appears that the problem is with reprojecting
>> (as the stackexchange user "nmtoken" had suspected). Leaflet seems to be
>> requesting 3857.
>> What would be the right course of action here? Should I tell Leaflet to do
>> the reprojection instead? Should I investigate further why mapserver has
>> trouble reprojecting (and how would I do that)? Should I reproject my data
>> files (GML) offline and store them in 3857 instead of 2100? Is there any
>> common/best practice regarding this?
>> Thanks!
>> Antonis
>> On 28/09/2022 17.47, Seth G wrote:
>>> Hi,
>>> Is there any change if you update the layer to have a single class with a
>>> simple line (no EXPRESSION, LABEL, MAXSCALEDENOM)?
>>> E.g.
>>>         CLASS
>>>             STYLE
>>>                 COLOR 0 0 255
>>>                 WIDTH 6
>>>             END
>>> Seth
>>> web:https://geographika.net
>>> twitter: @geographika
>>> On Wed, Sep 28, 2022, at 1:03 PM, Antonis Christofides wrote:
>>>> Hello,
>>>> I have a problem that has already been discussed in stackexchange
>>>> (https://gis.stackexchange.com/questions/440902/mapserver-wms-not-all-features-show-depending-on-how-i-zoom-and-pan
>>>> <https://gis.stackexchange.com/questions/440902/mapserver-wms-not-all-features-show-depending-on-how-i-zoom-and-pan>),
>>>> but without solution so far.
>>>> I'm repeating the full text here, but if there's any problem with the
>>>> images it might be better to go to stackexchange to read it.
>>>> Here is how QGIS shows an irrigation network, received by MapServer via WMS
>>>> and superimposed on OpenStreetMap:
>>>> enter image description here
>>>> Here is the same thing, but slightly panned to the right:
>>>> Several items are obviously missing. In fact there are items missing in the
>>>> top picture as well. Different items become visible as I zoom and pan
>>>> differently.
>>>> Since this pretty much tells the whole story, I'm not going into more
>>>> details. MapServer version is 7.6.2 (prepackaged for Debian). The base URL
>>>> is
>>>> https://poros.irmasys.com/cgi-bin/mapserv?map=/opt/aira-poros/aira-poros/mapserver/extralayers.map
>>>> <https://poros.irmasys.com/cgi-bin/mapserv?map=/opt/aira-poros/aira-poros/mapserver/extralayers.map>.
>>>> Finally, below I paste the interesting parts of the mapfile.
>>>> Thanks!
>>>> Antonis
>>>> |MAP NAME "aira-poros" STATUS ON SIZE 9040 7731 EXTENT 103986.57 3850796.18
>>>> 1007945.14 4623933.00 UNITS meters PROJECTION "init=epsg:2100" END CONFIG
>>>> MS_ERRORFILE "/var/log/mapserver/extralayers.log" # [Omitting some
>>>> OUTPUTFORMAT sections] WEB IMAGEPATH "/var/cache/mapserver/" IMAGEURL
>>>> "/mapserver_tmp/" METADATA "wms_title" "Aira Poros" "wms_onlineresource"
>>>> "https://poros.irmasys.com/cgi-bin/mapserv?map=/opt/aira-poros/aira-poros/mapserver/extralayers.map&"
>>>> <https://poros.irmasys.com/cgi-bin/mapserv?map=/opt/aira-poros/aira-poros/mapserver/extralayers.map&>
>>>> "wms_srs" "EPSG:4326 EPSG:2100 EPSG:3857" "wms_enable_request" "*"
>>>> "wms_feature_info_mime_type" "text/html" "wfs_title" "Aira Poros"
>>>> "wfs_onlineresource"
>>>> "wfs_srs" "EPSG:2100 EPSG:4326 EPSG:3857" "wfs_enable_request" "*" END END
>>>> LAYER NAME "irrigation-network" TYPE LINE CONNECTIONTYPE OGR CONNECTION
>>>> "irrigation-network.gml" METADATA "wms_title" "Irrigation network"
>>>> "wfs_title" "Irrigation network" "gml_include_items" "all" "gml_featureid"
>>>> "id" END STATUS ON PROJECTION "init=epsg:2100" END CLASSITEM 'category'
>>>> CLASS EXPRESSION '1' STYLE COLOR 0 0 255 OPACITY 50 WIDTH 6 END LABEL COLOR
>>>> 0 0 255 ANGLE FOLLOW OFFSET 5 99 MAXSCALEDENOM 10000 TEXT "[irri_code]" END
>>>> LABEL COLOR 0 0 255 ANGLE FOLLOW OFFSET -8 99 MAXSCALEDENOM 10000
>>>> EXPRESSION (NOT('[Diameter]' = '')) TEXT "D=[Diameter] mm" END END #
>>>> [Omitting three more classes] END # [Omitting four more layers] END|
>>>> _______________________________________________
>>>> MapServer-users mailing list
>>>> MapServer-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20221029/3286be00/attachment.htm>
More information about the MapServer-users mailing list
