[MapServer-users] Tutorials for creating time dimension images and good web frontends for dynamically changing map projects? (Solution for first problem)
Stefan Gofferje lists at home.gofferje.net
Sat Oct 15 00:34:21 PDT 2022
On 10/14/22 10:39, Stefan Gofferje wrote:
> After the relative ease of my first mapserver project, I'm now motivated
> and keen on getting another project running.
> Since about a year (plus minnus), I'm every day checking for Sentinel I
> and II data covering the area where I live. If there is anything, I
> download the data and run some scripts which do automatic processing and
> generating of composites, like SAR VV/VH or NDVI, NDCI, etc.
> The ready images are then posted to a Telegram channel.
> At the moment, there's still a number of manual steps (search data,
> decide what to download, trigger download, trigger processing and
> trigger Telegram push) and the existing scripts are Bash scripts calling
> GDAL tools.
> My first step now is to learn Python and move everything from Bash to
> Python and automate it, ideally so far that the whole process can run in
> a Docker container as a cron job.
> Then I was thinking, instead of pushing images to Telegram, I could use
> mapserver to serve the images to some web frontend. The map files are
> very easily created programmatically, so that should be easy. I'm
> missing a few things for that, though:
> While going through mapserver's docs, I noticed that it can handle time
> dimensions for imagery. That sounds like something worth exploring. The
> docs describe the use of a shape file but unfortunately, I have no clue
> how to to *create* that programmatically.
> Regarding the frontend, I could just put up a single page leaflet app.
> That would be easy enough. But I'm wondering if there's already some
> cool solutions out there.
> So, If anybody has a link or pointer for me on the programmatic creation
> of shape files for time-indexed imagery and/or interesting web frontend
> projects, I would be very grateful!
In case it is of use for anybody, here is the solution I came up with
last night:
1.) Add a time index metadatum to the output file
(gdaltranslate/gdal_edit -mo TIMEINDEX="yyyy-mm-ddThhmmZ"
2.) Hack together a Python script:
#!/usr/bin/python3
import os, sys
from osgeo import gdal
import geopandas as gpd
from shapely.geometry import box
import warnings
warnings.filterwarnings("ignore")
StartDir = str(sys.argv[1])
def getBounds(path):
     raster = gdal.Open(path)
     ulx, xres, xskew, uly, yskew, yres = raster.GetGeoTransform()
     lrx = ulx + (raster.RasterXSize * xres)
     lry = uly + (raster.RasterYSize * yres)
     return box(lrx, lry, ulx, uly)
df = gpd.GeoDataFrame(columns=['location', 'geometry','timestamp'])
for dir, subdir, files in os.walk(StartDir):
     for fname in files:
         if fname.endswith(".tif"):
             fullname = os.path.join(dir+"/", fname)
             print (fullname)
             ds=gdal.Open(fullname)
             metadata=ds.GetMetadata()
             ds=None
             print(metadata)
             df = df.append({'location': fname, 'geometry':
getBounds(fullname),'timestamp': metadata['TIMESTAMP']}, ignore_index=True)
#            df = gpd.pd.concat(df,{'location': fname, 'geometry':
getBounds(os.path.join(dir+"/", fname))}, ignore_index=True)
df.to_file("tile-index.shp")
NOTE: suppressing all warnings is temporary until I figured out how to
move from df.append to pd.concat.
-Stefan
  (o_   Stefan Gofferje            | SCLT, MCP, CCSA
  //\   Reg'd Linux User #247167   | VCP #2263
  V_/_  https://www.gofferje.net   | https://www.saakeskus.fi
More information about the MapServer-users mailing list
