[MapServer-users] Creating UTF grids with MapServer and MapCache
Scott public at postholer.com
Wed Sep 7 13:17:36 PDT 2022
In your .map file do you have the MVT format defined, something like:
  OUTPUTFORMAT
     NAME "mvt"
     DRIVER MVT
     FORMATOPTION "EDGE_BUFFER=10"
   END
On 9/7/22 12:38, karsten wrote:
> Thanks Scott,
> I do have a tileset like this below
>    <tileset name="flurst_utf_tiles">
> <metadata>
> <title>Flurst UTF</title>
> <abstract>Flurst UTF</abstract>
> </metadata>
> <source>flurst_utf</source>
> <cache>disk</cache>
>        <grid restricted_extent="727077.513504722 6536256.08499261
> 754566.10585149 6562363.18993406">GoogleMapsCompatible</grid>
> <format>mvt</format>
> <metatile>5 5</metatile>
> <metabuffer>10</metabuffer>
> <expires>3600</expires>
> </tileset>
> but also with this get the error
> tileset "flurst_utf_tiles" references format "mvt", but it is not configured
> *From:* karsten [mailto:karsten at terragis.net]
> *Sent:* Wednesday, September 07, 2022 12:08
> *To:* 'mapserver-users at lists.osgeo.org'
> *Subject:* Creating UTF grids with MapServer and MapCache
> Hi All,
> I am working on a correct configuration to cerate UTFGrid json tiles via
> MapCache and MapServerto seed a json tile set
> MapCache is up and running on my ubuntu 20 server and WMS requests (PNG,
> Jpeg ) are working as is the seeding utility.
> Now I am trying to add a UTFGrid tile layer and added the mvt format
> into the (working for the other layers correctly) mapcache.xml:
>     <format name="MVT" type="RAW">
>       <extension>mvt</extension>
>       <mime_type>application/vnd.mapbox-vector-tile</mime_type>
>     </format>
> the layer is
>     <source name="flurst_utf" type="wms">
>        <getmap>
>           <params>
>              <FORMAT>mvt</FORMAT>
>              <LAYERS>flurst</LAYERS>
>              <MAP>/var/mapdata/utfgrid.map</MAP>
>           </params>
>        </getmap>
>        <http>
>           <url>http://myserver/cgi-bin/mapserv</url>
>        </http>
>     </source>
> When tryign to restrart apache however I get this error message
> systemctl status apache2.service
> ● apache2.service - The Apache HTTP Server
>       Loaded: loaded (/lib/systemd/system/apache2.service; enabled;
> vendor preset: enabled)
>       Active: failed (Result: exit-code) since Wed 2022-09-07 20:31:58
> CEST; 28s ago
>         Docs: https://httpd.apache.org/docs/2.4/
> <https://httpd.apache.org/docs/2.4/>
>      Process: 1265907 ExecStart=/usr/sbin/apachectl start (code=exited,
> status=1/FAILURE)
> Sep 07 20:31:58 terraz systemd[1]: Starting The Apache HTTP Server...
> Sep 07 20:31:58 terraz apachectl[1265919]: AH00526: Syntax error on line
> 43 of /etc/apache2/sites-enabled/000-default.conf:
> Sep 07 20:31:58 terraz apachectl[1265919]: tileset "flurst_utf_tiles"
> Sep 07 20:31:58 terraz apachectl[1265907]: Action 'start' failed.
> What am I missing here ?
> Thanks
> Karsten Vennemann
> www.terragis.net <http://www.terragis.net>
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
