[MapServer-users] asking help
Boubacar Bah
bahbouba.909 at gmail.com
Sat Sep 24 14:23:26 PDT 2022
hello, i need your help regarding tinyows wfs transaction.
by the way I put in an online editing application.
in which I used the wfs transaction to send the request to my postgis
database.
but the problem is that if I edit an entity in the application the
transaction does not run to my database.
So I don't know where the problem is in my code.
Any help will be welcome.
Below is the code for the program in question:
<!DOCTYPE html>
<html>
<head>
<title>WFS - GetFeature</title>
<meta charset="utf-8"/>
<link rel="stylesheet" href="
https://cdn.jsdelivr.net/gh/openlayers/openlayers.github.io@master/en/v6.15.1/css/ol.css
" type="text/css">
<style>
.map {
height: 400px;
width: 100%;
</style>
<script src="
https://cdn.jsdelivr.net/gh/openlayers/openlayers.github.io@master/en/v6.15.1/build/ol.js
"></script>
</head>
<body>
<div id="map" class="map"></div>
<label >Modifier </label>
<button name="modifier" id="mod" value="Edit"></button>
<label >Creer </label>
<button name="Creer" id="creer" value="creer"></button>
<label >Stop Edition </label>
<button name="stop_modif" id="stop_mod" value="stop_Edit"></button>
<script>
var draw, modify, snap;
var maprojection= new ol.proj.Projection({
code:'EPSG:4326',
extent:[-20,30,20,50],
units:'degrees',
axisOrientation:'enu'
//surcharge de la projection EPSG:4326
ol.proj.addEquivalentProjections([ol.proj.get('EPSG:4326'),
maprojection]);
var wfsSource = new ol.source.Vector({
format: new ol.format.GeoJSON(),
url: function(extent) {
return 'http://127.0.0.1/cgi-bin/tinyows.exe?service=WFS&'+
'version=1.1.0&request=GetFeature&typename=tows:demo_tyny&'+
'outputFormat=application/json&srsname=EPSG:4326&'+
'bbox='+ extent.join(',')+',EPSG:4326';
strategy: ol.loadingstrategy.bbox,
projection: maprojection
var vector = new ol.layer.Vector({
source: wfsSource,
style: new ol.style.Style({
stroke: new ol.style.Stroke({
color: 'rgba(0,0,255,1.0)',
width:4
var map = new ol.Map({
layers:[vector],
target: document.getElementById('map'),
view: new ol.View({
projection: maprojection,
center: [2.5,46],
maxZoom: 20,
zoom: 1
var etat_edition= document.getElementById('mod');
var etat_creation= document.getElementById('creer');
var stop_edition= document.getElementById('stop_mod');
var draw, snap, modify; //declarees globalement pour les activers
ou non a la guise
var formatWFS = new ol.format.WFS();
var xs = new XMLSerializer();
var formatGML = new ol.format.GML3({
version:'1.1.0',
featureNS: 'http://www.mapserver.org/tinyows',
url: 'http://127.0.0.1/cgi-bin/tinyows.exe',
featureType:'demo_tyny',
srsName:'EPSG:4326',
geometryName: 'geom',
SchemaLocation:'
http://127.0.0.1/cgi-bin/tinyows.exe?service=wfs&request=DescribeFeatureType&version=1.1.0&typename=tows:demo_tyny
var transactWFS = function (mode, f) {
var node;
switch(mode) {
case 'insert':
mode = formatWFS.writeTransaction([f], null, null,
formatGML);
break;
case 'update':
node = formatWFS.writeTransaction(null, [f], null,
formatGML);
break;
case 'delete':
node = formatWFS.writeTransaction(null, null, [f],
formatGML);
break;
var xml_data = xs.serializeToString(node);
fetch('http://localhost/cgi-bin/tinyows.exe?service=wfs', {
method:'POST',
body: xml_data
}).then(function() {
wfsSource.clear();
function add_snap() {
snap = new ol.interaction.Snap({source: vector.getSource()});
map.addInteraction(snap);
function add_modify(){
stopInteractions();
add_snap();
modify = new ol.interaction.Modify({source: vector.getSource
map.addInteraction(modify)
function add_creer(){
stopInteractions();
add_snap();
draw = new ol.interaction.Draw({
source: vector.getSource(),
type:"MultiPolygon",
geometryName:'geom'
draw.on('drawend', function(e){
code_saisi=prompt("code_commune");
e.feature.setProperties({'code_commune':code_saisi});
transactWFS('insert',e.feature);
map.addInteraction(draw);
function stopInteractions() {
map.removeInteraction(draw);
map.removeInteraction(snap);
map.removeInteraction(modify)
etat_edition.onclick = function() {
add_modify();
etat_creation.onclick = function() {
add_creer();
stop_edition.onclick = function () {
stopInteractions();
</script>
</body>
</html>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220924/ff39e628/attachment-0001.htm>
More information about the MapServer-users
