[MapServer-users] What is the optimal value of requests per second for Mapserver?
Scott public at postholer.com
Thu Apr 20 07:16:30 PDT 2023
Depending on what you're doing, any bulk requests should be to a
pre-seeded MapCache and not the WMS server per se. In a production
environment a modestly detailed raster, it's easy to kill a WMS server
of any size.
You're going to have to test a range of requests to get a usable setup.
You may even consider limiting the size of bounding box requests.
On 4/20/23 06:59, Oskar Ravhed wrote:
> It is impossible to answer on without knowing what kind of for
> wms/wcs/wfs you are serving with mapserver
> For example a simple raster wms will be able to do many request per second.
> On the other side serve out osm from a postgis database will in some
> heavy scale not do more then 1 tile every 5 second
> I would determ it based on cpu/disk usage instead of request  per second
> On 20/04/2023 15:48, Marcin Niemyjski via MapServer-users wrote:
>> Hello
>> I'm looking for a benchmark advice.
>> If I have a machine running on 6 CPUs and 25gb RAM what would be the
>> value of the number of requests per second from which I should start
>> scaling my VMs with Mapserver?
>> Is there any way of testing or investingating? I'm using Locust and
>> JMeter but it's really hard to get a logical answer for this question.
>> Best,
>> Marcin
>> <https://outlook.office.com/bookwithme/user/6347c7def05a478ba013ae948648789d@cloudferro.com?anonymous&ep=signature>
>> 	Book time to meet with me
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
