[MapServer-users] Database problem when using CLASSITEM
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sun Apr 30 10:56:45 PDT 2023
Hi Jeremy,
I would run ogrinfo on that table to see what field to use for your
CLASSITEM, such as:
ogrinfo PG:"user=postgres password=postgres dbname=mdm6data
host=mxsig-db port=5432" tutoiral.states_ugl_imported -summary
(your timing is good as the tutorial was recently updated for MapServer 8 )
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2023-04-29 4:12 p.m., Jeremy JK wrote:
> Hola
> OK so I am going through the MapServer tutorial
> Example 1-3 to be exact
> the one with the classes
> using classes to split layer polygon into land and water
> when shp and dbf file is in filesystem it works fine
> But
> When I import shp file into postgres I get the following error
> After checking the error logs, my question is how do I get a class
> column? Do I have to insert the dbf file into schema? If so, how?
> Thanks
> *Error*:
> msDrawMap(): Image handling error. Failed to draw layer named
> 'states_poly'. msPostGISLayerWhichShapes(): Query error. Error executing
> query. Check server logs
More information about the MapServer-users
