[MapServer-users] Building mapserver on AlmaLinux with Oracle
Robert Hewlett rob.hewy at gmail.com
Sun Apr 23 14:14:46 PDT 2023
Hello All,
The end goal is to have mapserver compiled with both Oracle and PostGIS for
AlmaLinux 9.1 (Lime Lynx).
The package in EPEL+CRB has mapserver minus oracle.
Note, this is the first time building with cmake. I have most likely made
some rookie mistakes.
However, I feel the library names are slightly different e.g. Debian/Ubunut
vs RHEL naming conventions.
For instance the protobuf packages is installed:
/usr/lib64/libprotobuf-c.so.1
/usr/lib64/libprotobuf-c.so.1.0.0
/usr/lib64/libprotobuf.so.25
/usr/lib64/libprotobuf.so.25.0.0
The prefix pathi is:
 -DCMAKE_PREFIX_PATH=/usr/lib:/usr/lib64:/usr/local/pgsql:/usr/local:/opt
But I get an error as seen below:
  PROTOBUFC library/component/dependency could not be found.
    HINTS:
    - disable PROTOBUFC support by adding -DWITH_PROTOBUFC=0
    - add the PROTOBUFC install directory to the CMAKE_PREFIX_PATH variable
(-DCMAKE_PREFIX_PATH="/path/to/PROTOBUFC-install-dir;/path/to/other/dirs"
Call Stack (most recent call first):
  CMakeLists.txt:339 (report_optional_not_found)
Any help would be appreciated,
Rob
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230423/e91d9841/attachment.htm>
More information about the MapServer-users mailing list
