[MapServer-users] multiple shapepaths
Steve Lime sdlime at gmail.com
Sat Dec 2 10:29:11 PST 2023
One other thought, you can use multiple paths via runtime subs to
approximate what I think you’re looking for, so:
WEB
  VALIDATION
    path1_default “/opt/path1”
    path1 “^\/opt\/path1$”
    path2_default “/opt/path2”
    path2 “^\/opt\/path2$”
  END
END
Then in DATA values you’d use %path1% or %path2%. This is another use case
for variables that was suggested recently. We could, perhaps, define a way
to mark something as immutable via url so the regex could be simplified and
only the default would ever be used (e.g. “path2” “immutable”).
—Steve
On Fri, Dec 1, 2023 at 11:28 PM Steve Lime <sdlime at gmail.com> wrote:
> Nope, just the one value.
> On Fri, Dec 1, 2023 at 1:02 PM Jan Hartmann via MapServer-users <
> mapserver-users at lists.osgeo.org> wrote:
>> Hi,
>> Is it possible to use multiple paths in a shapepath? ./data1:./data2
>> does not work
>> Jan
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231202/592fba8e/attachment.htm>
More information about the MapServer-users mailing list
