[MapServer-users] multiple shapepaths
Jörg Thomsen (WhereGroup) joerg.thomsen at wheregroup.com
Mon Dec 4 01:10:30 PST 2023
I am not sure, but perhaps overwriting it, would work?
MAP
   shapepath 'blah'
   Layer 1
   Layer 2
   shapepath 'blubb'
   Layer 3
   Layer 4
Jörg
Am 02.12.23 um 19:32 schrieb Jan Hartmann via MapServer-users:
> Yes, that is what I sought, didn't know it was possible. Thanks!
> Jan
> On 02/12/2023 19:29, Steve Lime wrote:
>> One other thought, you can use multiple paths via runtime subs to
>> approximate what I think you’re looking for, so:
>> WEB
>>   VALIDATION
>>     path1_default “/opt/path1”
>>     path1 “^\/opt\/path1$”
>>   path2_default “/opt/path2”
>>   path2 “^\/opt\/path2$”
>>   END
>> END
>> Then in DATA values you’d use %path1% or %path2%. This is another use
>> case for variables that was suggested recently. We could, perhaps,
>> define a way to mark something as immutable via url so the regex could
>> be simplified and only the default would ever be used (e.g. “path2”
>> “immutable”).
>> —Steve
>> On Fri, Dec 1, 2023 at 11:28 PM Steve Lime <sdlime at gmail.com> wrote:
>>     Nope, just the one value.
>>     On Fri, Dec 1, 2023 at 1:02 PM Jan Hartmann via MapServer-users
>>     <mapserver-users at lists.osgeo.org> wrote:
>>         Hi,
>>         Is it possible to use multiple paths in a shapepath?
>>         ./data1:./data2
>>         does not work
>>         Jan
>>         _______________________________________________
>>         MapServer-users mailing list
>>         MapServer-users at lists.osgeo.org
>>         https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
Where2B Konferenz 2023
14. Dezember 2023 in Bonn und Online
https://where2b-conference.com/
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the MapServer-users mailing list
