[MapServer-users] multiple shapepaths
Steve Lime sdlime at gmail.com
Tue Dec 5 06:43:40 PST 2023
It won’t work. A configuration is loaded in entirety first, and then
applied as necessary.
On Tue, Dec 5, 2023 at 7:21 AM Jan Hartmann via MapServer-users <
mapserver-users at lists.osgeo.org> wrote:
> Not sure. I cannot get it working anyway. Any ideas, Steve?
> On 04/12/2023 10:10, Jörg Thomsen (WhereGroup) via MapServer-users wrote:
> > Hi,
> > I am not sure, but perhaps overwriting it, would work?
> > MAP
> >   shapepath 'blah'
> >   Layer 1
> >   Layer 2
> >   shapepath 'blubb'
> >   Layer 3
> >   Layer 4
> > Jörg
> > Am 02.12.23 um 19:32 schrieb Jan Hartmann via MapServer-users:
> >> Yes, that is what I sought, didn't know it was possible. Thanks!
> >> Jan
> >> On 02/12/2023 19:29, Steve Lime wrote:
> >>> One other thought, you can use multiple paths via runtime subs to
> >>> approximate what I think you’re looking for, so:
> >>> WEB
> >>>   VALIDATION
> >>>     path1_default “/opt/path1”
> >>>     path1 “^\/opt\/path1$”
> >>>   path2_default “/opt/path2”
> >>>   path2 “^\/opt\/path2$”
> >>>   END
> >>> END
> >>> Then in DATA values you’d use %path1% or %path2%. This is another
> >>> use case for variables that was suggested recently. We could,
> >>> perhaps, define a way to mark something as immutable via url so the
> >>> regex could be simplified and only the default would ever be used
> >>> (e.g. “path2” “immutable”).
> >>> —Steve
> >>> On Fri, Dec 1, 2023 at 11:28 PM Steve Lime <sdlime at gmail.com> wrote:
> >>>     Nope, just the one value.
> >>>     On Fri, Dec 1, 2023 at 1:02 PM Jan Hartmann via MapServer-users
> >>>     <mapserver-users at lists.osgeo.org> wrote:
> >>>         Hi,
> >>>         Is it possible to use multiple paths in a shapepath?
> >>>         ./data1:./data2
> >>>         does not work
> >>>         Jan
> >>>         _______________________________________________
> >>>         MapServer-users mailing list
> >>>         MapServer-users at lists.osgeo.org
> >>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231205/419acdbe/attachment.htm>
More information about the MapServer-users mailing list
