[MapServer-users] multiple shapepaths
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Wed Dec 6 12:23:49 PST 2023
Or write the DATA with full-path into an INCLUDE file if there are loads of mapfiles using the same paths. Then there would be much less editing when the paths change.
-Jukka Rahkonen-
Lähettäjä: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Lime, Steve D (MNIT) via MapServer-users
Lähetetty: keskiviikko 6. joulukuuta 2023 21.59
Vastaanottaja: j.l.h.hartmann at gmail.com; Steve Lime <sdlime at gmail.com>
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [MapServer-users] multiple shapepaths
IMHO, if you do a SHAPEPATH at the layer level then you might as well just add the full-path to the DATA element. You’re not really gaining anything with the additional complexity. Did the idea of using runtime variables not pan out?
From: MapServer-users <mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>> On Behalf Of Jan Hartmann via MapServer-users
Sent: Wednesday, December 6, 2023 1:14 AM
To: Steve Lime <sdlime at gmail.com<mailto:sdlime at gmail.com>>
Cc: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: Re: [MapServer-users] multiple shapepaths
How about a shapepath at the layer level? I am combining 20 years of working with old maps in three (or four :-)) different countries (Netherlands, Germany and Flemish and Walloon Belgium), all in their own formats, projections, directories an servers. It would help to keep my applications (and my mind) clear if I could use the appropriate shapepaths. And as to portability, it is essential to use relative paths. Just try to move a website to a new server with a differently named filesystem, if all paths are hard coded.
Jan
Op 5 dec 2023 om 15:43 heeft Steve Lime <sdlime at gmail.com<mailto:sdlime at gmail.com>> het volgende geschreven:
It won’t work. A configuration is loaded in entirety first, and then applied as necessary.
On Tue, Dec 5, 2023 at 7:21 AM Jan Hartmann via MapServer-users <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>> wrote:
Not sure. I cannot get it working anyway. Any ideas, Steve?
On 04/12/2023 10:10, Jörg Thomsen (WhereGroup) via MapServer-users wrote:
> Hi,
> I am not sure, but perhaps overwriting it, would work?
> MAP
>   shapepath 'blah'
>   Layer 1
>   Layer 2
>   shapepath 'blubb'
>   Layer 3
>   Layer 4
> Jörg
> Am 02.12.23 um 19:32 schrieb Jan Hartmann via MapServer-users:
>> Yes, that is what I sought, didn't know it was possible. Thanks!
>> Jan
>> On 02/12/2023 19:29, Steve Lime wrote:
>>> One other thought, you can use multiple paths via runtime subs to
>>> approximate what I think you’re looking for, so:
>>> WEB
>>>   VALIDATION
>>>     path1_default “/opt/path1”
>>>     path1 “^\/opt\/path1$”
>>>   path2_default “/opt/path2”
>>>   path2 “^\/opt\/path2$”
>>>   END
>>> END
>>> Then in DATA values you’d use %path1% or %path2%. This is another
>>> use case for variables that was suggested recently. We could,
>>> perhaps, define a way to mark something as immutable via url so the
>>> regex could be simplified and only the default would ever be used
>>> (e.g. “path2” “immutable”).
>>> —Steve
>>> On Fri, Dec 1, 2023 at 11:28 PM Steve Lime <sdlime at gmail.com<mailto:sdlime at gmail.com>> wrote:
>>>     Nope, just the one value.
>>>     On Fri, Dec 1, 2023 at 1:02 PM Jan Hartmann via MapServer-users
>>>         Hi,
>>>         Is it possible to use multiple paths in a shapepath?
>>>         ./data1:./data2
>>>         does not work
>>>         Jan
>>>         _______________________________________________
>>>         MapServer-users mailing list
>>>         MapServer-users at lists.osgeo.org<mailto:MapServer-users at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231206/780c7cd8/attachment.htm>
More information about the MapServer-users mailing list
