[MapServer-users] Shapefile of Points
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Thu Dec 21 05:26:17 PST 2023
here are a lot of examples for symbol-definitions and using them in the
mapfile: https://mapserver.org/mapfile/symbology/construction.html
> I intend to create 32 point symbols by varying the color,
you'll need only one symbol-definition. assign the color in the mapfiles
style-section.
> I have a suspicion that I should use mapscript to assign the symbols to
> each data range from php, for example, if the range is between 0-1.99,
> strong red symbol, 2.00-3.99 light red symbol...
this is done bei the EXPRESSION within the class-section
see https://mapserver.org/mapfile/class.html
> I'm doing this in qgis, and each shapefile has a different set of data
> in range, this makes me think that I should calculate the quantiles from
> the shapefile data and then assign the color symbols using php and
> mapscript to create the .map file
you can do the classification in qgis and use the extension 'GeoCat
Bridge' to create the layer-sections of your mapfile.
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com/
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the MapServer-users
