[MapServer-users] multiple shapepaths
Jan Hartmann
j.l.h.hartmann at gmail.com
Wed Dec 6 06:39:49 PST 2023
No, this would make the file system on my server an even worse spaghetti
mess than when I move the files physically under one root. I want to
leave everything as distributed as possible.
Cheers, Rich, Steve and all,
Jan
On 06/12/2023 14:21, Richard Greenwood wrote:
> How about just symlink in the file system?
> On Wed, Dec 6, 2023 at 12:14 AM Jan Hartmann via MapServer-users
> <mapserver-users at lists.osgeo.org> wrote:
> How about a shapepath at the layer level? I am combining 20 years
> of working with old maps in three (or four :-)) different
> countries (Netherlands, Germany and Flemish and Walloon Belgium),
> all in their own formats, projections, directories an servers. It
> would help to keep my applications (and my mind) clear if I could
> use the appropriate shapepaths. And as to portability, it is
> essential to use relative paths. Just try to move a website to a
> new server with a differently named filesystem, if all paths are
> hard coded.
> Jan
>> Op 5 dec 2023 om 15:43 heeft Steve Lime <sdlime at gmail.com> het
>> volgende geschreven:
>> It won’t work. A configuration is loaded in entirety first, and
>> then applied as necessary.
>> On Tue, Dec 5, 2023 at 7:21 AM Jan Hartmann via MapServer-users
>> Not sure. I cannot get it working anyway. Any ideas, Steve?
>> On 04/12/2023 10:10, Jörg Thomsen (WhereGroup) via
>> MapServer-users wrote:
>> > Hi,
>> > I am not sure, but perhaps overwriting it, would work?
>> > MAP
>> > shapepath 'blah'
>> > Layer 1
>> > Layer 2
>> > shapepath 'blubb'
>> > Layer 3
>> > Layer 4
>> > Jörg
>> > Am 02.12.23 um 19:32 schrieb Jan Hartmann via MapServer-users:
>> >> Yes, that is what I sought, didn't know it was possible.
>> Thanks!
>> >> Jan
>> >> On 02/12/2023 19:29, Steve Lime wrote:
>> >>> One other thought, you can use multiple paths via runtime
>> subs to
>> >>> approximate what I think you’re looking for, so:
>> >>> WEB
>> >>> VALIDATION
>> >>> path1_default “/opt/path1”
>> >>> path1 “^\/opt\/path1$”
>> >>> path2_default “/opt/path2”
>> >>> path2 “^\/opt\/path2$”
>> >>> END
>> >>> END
>> >>> Then in DATA values you’d use %path1% or %path2%. This is
>> another
>> >>> use case for variables that was suggested recently. We
>> could,
>> >>> perhaps, define a way to mark something as immutable via
>> url so the
>> >>> regex could be simplified and only the default would ever
>> be used
>> >>> (e.g. “path2” “immutable”).
>> >>> —Steve
>> >>> On Fri, Dec 1, 2023 at 11:28 PM Steve Lime
>> <sdlime at gmail.com> wrote:
>> >>> Nope, just the one value.
>> >>> On Fri, Dec 1, 2023 at 1:02 PM Jan Hartmann via
>> MapServer-users
>> >>> Hi,
>> >>> Is it possible to use multiple paths in a shapepath?
>> >>> ./data1:./data2
>> >>> does not work
>> >>> Jan
>> >>> _______________________________________________
>> >>> MapServer-users mailing list
>> >>> MapServer-users at lists.osgeo.org
>> >>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Richard W. Greenwood
> www.greenwoodmap.com <http://www.greenwoodmap.com>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231206/273a5c10/attachment-0001.htm>
More information about the MapServer-users
