[MapServer-users] multiple shapepaths
Jan Hartmann
j.l.h.hartmann at gmail.com
Wed Dec 13 09:39:06 PST 2023
No, this is too complex. And Steve's runtime-substutions with %path% in
de URL probably does not work. I don't see how that could be done in
PHP-MapScript.
On 06/12/2023 21:23, Rahkonen Jukka wrote:
> Hi,
> Or write the DATA with full-path into an INCLUDE file if there are
> loads of mapfiles using the same paths. Then there would be much less
> editing when the paths change.
> -Jukka Rahkonen-
> *Lähettäjä:* MapServer-users <mapserver-users-bounces at lists.osgeo.org>
> *Puolesta *Lime, Steve D (MNIT) via MapServer-users
> *Lähetetty:* keskiviikko 6. joulukuuta 2023 21.59
> *Vastaanottaja:* j.l.h.hartmann at gmail.com; Steve Lime <sdlime at gmail.com>
> *Kopio:* mapserver-users at lists.osgeo.org
> *Aihe:* Re: [MapServer-users] multiple shapepaths
> IMHO, if you do a SHAPEPATH at the layer level then you might as well
> just add the full-path to the DATA element. You’re not really gaining
> anything with the additional complexity. Did the idea of using runtime
> variables not pan out?
> *From:*MapServer-users <mapserver-users-bounces at lists.osgeo.org> *On
> Behalf Of *Jan Hartmann via MapServer-users
> *Sent:* Wednesday, December 6, 2023 1:14 AM
> *To:* Steve Lime <sdlime at gmail.com>
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [MapServer-users] multiple shapepaths
> How about a shapepath at the layer level? I am combining 20 years of
> working with old maps in three (or four :-)) different countries
> (Netherlands, Germany and Flemish and Walloon Belgium), all in their
> own formats, projections, directories an servers. It would help to
> keep my applications (and my mind) clear if I could use the
> appropriate shapepaths. And as to portability, it is essential to use
> relative paths. Just try to move a website to a new server with a
> differently named filesystem, if all paths are hard coded.
> Jan
> Op 5 dec 2023 om 15:43 heeft Steve Lime <sdlime at gmail.com> het
> volgende geschreven:
> It won’t work. A configuration is loaded in entirety first, and
> then applied as necessary.
> On Tue, Dec 5, 2023 at 7:21 AM Jan Hartmann via MapServer-users
> <mapserver-users at lists.osgeo.org> wrote:
> Not sure. I cannot get it working anyway. Any ideas, Steve?
> On 04/12/2023 10:10, Jörg Thomsen (WhereGroup) via
> MapServer-users wrote:
> > Hi,
> > I am not sure, but perhaps overwriting it, would work?
> > MAP
> > shapepath 'blah'
> > Layer 1
> > Layer 2
> > shapepath 'blubb'
> > Layer 3
> > Layer 4
> > Jörg
> > Am 02.12.23 um 19:32 schrieb Jan Hartmann via MapServer-users:
> >> Yes, that is what I sought, didn't know it was possible.
> Thanks!
> >> Jan
> >> On 02/12/2023 19:29, Steve Lime wrote:
> >>> One other thought, you can use multiple paths via runtime
> subs to
> >>> approximate what I think you’re looking for, so:
> >>> WEB
> >>> VALIDATION
> >>> path1_default “/opt/path1”
> >>> path1 “^\/opt\/path1$”
> >>> path2_default “/opt/path2”
> >>> path2 “^\/opt\/path2$”
> >>> END
> >>> END
> >>> Then in DATA values you’d use %path1% or %path2%. This is
> another
> >>> use case for variables that was suggested recently. We could,
> >>> perhaps, define a way to mark something as immutable via
> url so the
> >>> regex could be simplified and only the default would ever
> be used
> >>> (e.g. “path2” “immutable”).
> >>> —Steve
> >>> On Fri, Dec 1, 2023 at 11:28 PM Steve Lime
> <sdlime at gmail.com> wrote:
> >>> Nope, just the one value.
> >>> On Fri, Dec 1, 2023 at 1:02 PM Jan Hartmann via
> MapServer-users
> >>> Hi,
> >>> Is it possible to use multiple paths in a shapepath?
> >>> ./data1:./data2
> >>> does not work
> >>> Jan
> >>> _______________________________________________
> >>> MapServer-users mailing list
> >>> MapServer-users at lists.osgeo.org
> >>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231213/38361803/attachment-0001.htm>
More information about the MapServer-users
