[MapServer-users] Changing opacity of one layer in a multilayer WMS request URL with MapServer 8
Matthew Graber grabermtw at gmail.com
Tue Feb 21 08:52:04 PST 2023
Hello all!
With MapServer 8, I'm wondering what the proper way to change the opacity
of a single layer in a multilayer WMS request is.
For example, the following URL excerpt shows the old way of accomplishing
this that worked while using MapServer 7:
SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&LAYERS=test_a,test_b&map.layer[test_b]=OPACITY+50
My understanding is that this would have the same effect as adding "OPACITY
50" to the test_b layer in the mapfile. The mapfile containing test_a and
test_b did not have OPACITY included when they were written. Obviously,
this no longer works with MapServer 8, and now that request has the same
results as omitting the "&map.layer[test_b]=OPACITY+50" portion entirely.
Based on https://mapserver.org/fr/MIGRATION_GUIDE.html, I see that OPACITY
now belongs inside a COMPOSITE object. I tried the following modifications
to the request URL:
SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&LAYERS=test_a,test_b&map.layer[test_b].composite=OPACITY+50
SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&LAYERS=test_a,test_b&map.layer[test_b].composite[0]=OPACITY+50
I also tried this both with the mapfile left as-is, and with an empty
COMPOSITE object being included in each layer object, and each time I got
the same unsuccessful result as before.
Is there a way to accomplish this in MapServer 8?
Also, does this map.layer[layername]=... syntax still work in MapServer 8?
The documentation at
https://mapserver.org/cgi/controls.html#using-mapserver-version-8 suggests
it might no longer work for MapServer 8 (based on the heading "Using
MapServer version < 8"), but the documentation at
https://mapserver.org/pdf/MapServer.pdf shows the same examples with the
heading "Using MapServer version <= 8" on page 1065 of the PDF, so I'm
unsure if this is still intended to work in MapServer 8.
Thank you,
Matt
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230221/f98c0e42/attachment.htm>
More information about the MapServer-users mailing list
