[MapServer-users] [EXTERNAL] Two regular expressions
Preuß, Sylvia
Sylvia.Preuss at obk.de
Thu Feb 9 01:16:09 PST 2023
Thank you very much.
Von: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Im Auftrag von Lime, Steve D (MNIT) via MapServer-users
Gesendet: Mittwoch, 8. Februar 2023 15:37
An: Schylberg Lars <lars.schylberg at saabgroup.com>; mapserver-users at lists.osgeo.org
Betreff: Re: [MapServer-users] [EXTERNAL] Two regular expressions
You can also match either with something like:
^(GERMAN|FRENCH)$
A good resource for testing is https://www.regextester.com/ and there others out there too.
--Steve
From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> On Behalf Of Schylberg Lars
Sent: Wednesday, February 8, 2023 2:07 AM
To: 'mapserver-users at lists.osgeo.org' <mapserver-users at lists.osgeo.org>
Subject: Re: [MapServer-users] [EXTERNAL] Two regular expressions
You need to use a CLASSITEM
LAYER
CLASSITEM "LANGUAGE"
CLASS
EXPRESSION /^GERMAN$/
EXPRESSION /^FRENCH$/
Have fun / Lars S.
From: MapServer-users <mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>> On Behalf Of Preuß, Sylvia
Sent: den 8 februari 2023 08:24
To: 'mapserver-users at lists.osgeo.org' <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: [EXTERNAL] [MapServer-users] Two regular expressions
Hello,
is it possible to do something like that with a regular expression
MAP...
EXPRESSION ('[LANGUAGE]' eq 'GERMAN' OR '[LANGUAGE]' eq 'FRENCH')?
...END
my regular expressions include ^ and $:
EXPRESSION /^RMA$/
EXPRESSION /^RENC$/
Thanks
sylviaobk
Der E-Mail-Dienst des Oberbergischen Kreises dient ausschließlich der dienstlichen Kommunikation.
Senden Sie deshalb keine E-Mails privaten Inhalts an E-Mail-Adressen des Oberbergischen Kreises.
Es wird darauf hingewiesen, dass neben der Person, an die Ihre E-Mail gerichtet ist, auch deren Vertretung im Amt einen unmittelbaren Zugriff auf Ihre Nachricht hat. Für Berufsgeheimnisträger und besondere Funktionsträger gelten abweichende Regelungen.
Es wird außerdem darauf hingewiesen, dass die Kommunikation per E-Mail ohne Authentifizierung und Verschlüsselung unsicher ist, da für unberechtigte Dritte grundsätzlich die Möglichkeit der Kenntnisnahme und Manipulation besteht.
Es wird deshalb keine Verantwortung für den Inhalt dieser Nachricht übernommen, da eine Manipulation nicht ausgeschlossen werden kann.
Obwohl alle angemessenen Vorkehrungen getroffen wurden, um sicherzustellen, dass Anlagen dieser E-Mail virusgeprüft sind, wird empfohlen, anhängende Dateien vor dem Öffnen durch Ihr eigenes Virus-Programm zu prüfen, da keinerlei Haftung für Schäden übernommen wird, die infolge etwaiger Software-Viren entstehen könnten.
Der Inhalt dieser E-Mail ist ausschließlich für die bezeichnete Person bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen Vertretung sein sollten, beachten Sie bitte, dass jede Form der Kenntnisnahme, Veröffentlichung, Vervielfältigung oder Weitergabe des Inhalts dieser E-Mail unzulässig ist. In diesem Fall wird darum gebeten, sich mit der absendenden Person der E-Mail in Verbindung zu setzen.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230209/454c63da/attachment-0001.htm>
More information about the MapServer-users
