[MapServer-users] MSSQL plugin path outside of the global CONFIG file
Benedek Petrovicz
benedek.petrovicz at gmail.com
Mon Mar 20 06:51:27 PDT 2023
Hi!
Before MapServer 8, I always defined the mssql plugin path in the mapfiles
directly.
It was a convenient way for my use case.
Now from MapServer 8 there's the required global CONFIG file I have to
define.
Which is fine, but MapServer will only allow loading the plugin through
that global CONFIG file.
The CONFIG reference states the following:
*"PLUGINS: This block allows for keys to be mapped to plugin library
paths."*
For me, this means I can define a global plugin keyword if I want to, but I
don't have to.
In reality I don't have other options. At least I don't know about any.
Is it mandatory now, to define the PLUGIN path from the global CONFIG file?
Thank you!
Benedek Petrovicz
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230320/e58ee5e0/attachment.htm>
More information about the MapServer-users
