[MapServer-users] Database problem when using CLASSITEM
Jeremy JK
jason2017jay at gmail.com
Mon May 1 12:49:19 PDT 2023
Hi Bob,
Thanks for the guidance
I had been "misdirected" by the mentioning of the dbf file in tutorial
Hope you guys can clear up some more of my misdirections in the future
On Mon, May 1, 2023, 9:59 AM Bob Basques <bob.basques at ci.stpaul.mn.us>
wrote:
> *Jeremy,*
> *One thing to check is the column name in Postgres, as in “CLASS” vs
> “class” vs “Class”, etc. Needs to match. Check the same thing on
> EXPRESSION values.*
> *bobb*
> *My machine - - - PW19-S295-C024*
> *From:* MapServer-users <mapserver-users-bounces at lists.osgeo.org> *On
> Behalf Of *Jeremy JK
> *Sent:* Saturday, April 29, 2023 2:12 PM
> *To:* Jason Snyder <mapserver-users at lists.osgeo.org>
> *Subject:* [MapServer-users] Database problem when using CLASSITEM
> *Think Before You Click: *This email originated *outside *our
> organization.
> Hola
> OK so I am going through the MapServer tutorial
> Example 1-3 to be exact
> the one with the classes
> using classes to split layer polygon into land and water
> when shp and dbf file is in filesystem it works fine
> But
> When I import shp file into postgres I get the following error
> After checking the error logs, my question is how do I get a class column?
> Do I have to insert the dbf file into schema? If so, how?
> Thanks
> *Error*:
> msDrawMap(): Image handling error. Failed to draw layer named
> 'states_poly'. msPostGISLayerWhichShapes(): Query error. Error executing
> query. Check server logs
> *Query: *
> http://localhost:8081/cgi-bin/mapserv?map=/opt/map/mdm60/example1-3.map&layer=states_poly&layer=states_line&mode=map
> *Mapfile*:
> MAP
> IMAGETYPE PNG
> EXTENT -97.238976 41.619778 -82.122902 49.385620
> SIZE 400 300
> SHAPEPATH "/opt/map/mdm60/ms4w/apps/tutorial/data/"
> IMAGECOLOR 255 255 255
> LAYER
> NAME "states_poly"
> CONNECTIONTYPE POSTGIS
> CONNECTION "user=postgres password=postgres dbname=mdm6data
> host=mxsig-db port=5432"
> DATA "wkb_geometry from tutoiral.states_ugl_imported using
> srid=3857"
> STATUS OFF
> TYPE POLYGON
> CLASSITEM "CLASS"
> CLASS
> NAME 'States'
> EXPRESSION 'land'
> STYLE
> COLOR 232 232 232
> END
> END
> CLASS
> NAME 'Water'
> EXPRESSION 'water'
> STYLE
> COLOR 198 198 255
> END
> END
> END
> LAYER
> NAME "states_line"
> DATA "wkb_geometry from tutorial.sttes_ugl_imported using
> srid=3875"
> STATUS OFF
> TYPE LINE
> CLASSITEM "CLASS"
> CLASS
> NAME 'State Boundary'
> EXPRESSION 'land'
> STYLE
> COLOR 32 32 32
> END
> END
> END
> END
> *Error Log: *[Sat Apr 29 19:08:42 2023].232185 CGI Request 1 on process
> 1677
> [Sat Apr 29 19:08:42 2023].233452 msDrawMap(): rendering using
> outputformat named png (AGG/PNG).
> [Sat Apr 29 19:08:42 2023].233473 msDrawMap(): WMS/WFS set-up and query,
> 0.000s
> [Sat Apr 29 19:08:42 2023].282742 msPostGISLayerWhichShapes(): Error
> (ERROR: no existe la columna «CLASS»
> LINE 1: select "CLASS"::text,ST_AsBinary(("wkb_geometry"),'NDR') as ...
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230501/d3ec6789/attachment.htm>
More information about the MapServer-users
