[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu May 4 10:13:11 PDT 2023
Thanks. I think you solved any validation issues ( this request would
not validate, for example :
https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map
) so it's something else, very minor likely (I've got that t-shirt
too, ha)
-jeff
On 2023-05-04 2:00 p.m., Chris Cantey wrote:
> Thanks, Jeff.. I found that out, thanks.
> I will work down from your points.
> Besc,
> On Thu, May 4, 2023 at 11:57 AM Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
> Also note, that the regular expression "^" trick applies to the
> MS_MAP_PATTERN in the config file (not the MS_ERRORFILE path in the
> mapfile).
> Thanks for using MapServer Chris,
> -jeff
> Jeff McKenna
> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> co-founder of FOSS4G
> http://gatewaygeo.com/ <http://gatewaygeo.com/>
> On 2023-05-04 1:48 p.m., Jeff McKenna wrote:
> > More points for your consideration:
> > - make sure all layers have a PROJECTION object
> > - remove any old references to the (non-standard/non-existing)
> > EPSG:900913, replace with EPSG:3857 (see https://epsg.io/3857
> <https://epsg.io/3857> )
> > - remove all warnings from your GetCapabilities response, every
> single
> > warning, there should be no warnings in the response, before you
> move to
> > testing GetMap requests
> > - if you have PostGIS/db connections, consider setting EXTENT at the
> > layer-level, to improve speed for your clients (review
> optimizations at
> > https://mapserver.org/optimization/vector.html
> <https://mapserver.org/optimization/vector.html> )
> > - during GetMap testing, comment any TEMPLATE params in mapfile
> > -jeff
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org <mailto:MapServer-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
> Chris Cantey
> geo-odyssey.com <http://geo-odyssey.com>
Jeff McKenna
More information about the MapServer-users
