[MapServer-users] breaking changes in branch-7-6 after commit of experimental changes from branch-8-0
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Tue May 30 04:27:43 PDT 2023
Maybe the commit could be adjusted in Mapserver 7. Out of curiosity, what is the use case for zero sized labels and symbols? To disable them, or? About the angle, by the Mapserver 7.0 documentation, doesn't it feel like negative angles were not thought to work ever?
"Angle, given in degrees, to rotate the symbol (counter clockwise). Default is 0 (no rotation). If you have an attribute that specifies angles in a clockwise direction (compass direction), you have to adjust the angle attribute values before they reach MapServer (360-ANGLE), as it is not possible to use a mathematical expression for ANGLE."
-Jukka Rahkonen-
Lähettäjä: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Oliver Christen
Lähetetty: tiistai 30. toukokuuta 2023 13.59
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [MapServer-users] breaking changes in branch-7-6 after commit of experimental changes from branch-8-0
Dear Mapserver commiters
this commit there:
https://github.com/MapServer/MapServer/pull/6818
broke a lot of things,
like style angles not supporting negative values anymore or label size mandatorily greater than zero (also possibly for symbol)
Im not against changes, but changes should be:
a) documented
b) announced with preferably a deprecation period
so, please revert that commit or provide adequate change/documentation for all the breaking changes.
Thank you
Best regards
Oliver Christen
[https://lh5.googleusercontent.com/4RpzNqlUvMoqWPtwuUWigz1_dKPkUN4OQOKshy_zixf9Gi6JzQJRjs3oHwxYaiADK7htQjUTodRa-OUr4YEKbgs9SsmqPG6QYjqKj3wbXoQ6snhaqq2eEJTeB1FZHKK7SApWcSZk45Fe3w4grA]<https://www.camptocamp.com/en/news-events/camptocamp-flagship-office-bussigny>
New address from 1st September 2022
Camptocamp SA
Route de la Chaux 4
1030 Bussigny
Suisse
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230530/0c739fcc/attachment.htm>
More information about the MapServer-users mailing list
