[MapServer-users] breaking changes in branch-7-6 after commit of experimental changes from branch-8-0
Steve Lime sdlime at gmail.com
Tue May 30 14:20:27 PDT 2023
This is my fault... The intention was to localize those bounds checks in a
benign manner. However, I should have known that restricting angle to 0-360
might catch someone off guard and loosened that for the 7.6 backport. Those
changes had been in the 8.0 branch for many months with zero negative
feedback. We could issue a 7.6.6 release with a -360 to 360 range. I've not
heard of any other related issues with that change.
--Steve
On Tue, May 30, 2023 at 7:45 AM Rahkonen Jukka <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> It looks like Steve Lime was reading the text in the paragraph and not the
> line the defines the synopsis and thought that the documentation was
> explicit
> https://github.com/MapServer/MapServer/issues/6463#issuecomment-1025938850
> “since style-level angle documentation refers specifically to 0-360 I
> think we should limit from 0-360 if there are no objections”. Or maybe he
> was remembering what he was thinking when writing the original code?
> Please make a pull request for improving the documentation, for my mind it
> is vague now.
> -Jukka Rahkonen-
> *Lähettäjä:* Oliver Christen <oliver.christen at camptocamp.com>
> *Lähetetty:* tiistai 30. toukokuuta 2023 15.21
> *Vastaanottaja:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
> *Kopio:* mapserver-users at lists.osgeo.org
> *Aihe:* Re: [MapServer-users] breaking changes in branch-7-6 after commit
> before that commit, the following code was working:
>     STYLE
>       COLOR 255 255 255
>       SYMBOL "rectangle3"
>       ANGLE -45
>       SIZE 8
>       GAP 10
>     END
> after that commit, it no longer works, as ANGLE -45 is not accepted
> anymore, instead it had to be changed to
> STYLE
>       COLOR 255 255 255
>       SYMBOL "rectangle3"
>       ANGLE 315
>       SIZE 8
>       GAP 10
>     END
> the documentation https://mapserver.org/mapfile/style.html say it must be
> of type DOUBLE, but double can be negative and nothing say explicitly in
> the documentation that the value can not be negative.
> I see this discussion here:
> but no comment if something was done or agreed on about this.
> A note should be added to the documentation to make that clear, as it was
> done for label size (see below).
> I can do a PR if that would be acceptable ?
> for label size, I see that a note was added saying the value must be
> greater than zero on 26 january 2022, so I guess this is on me for not
> noticing it (but im not alone not noticing it so I guess it wasnt clearly
> stated/announced either)
> Best regards
> Oliver
> On Tue, May 30, 2023 at 1:27 PM Rahkonen Jukka <
> Hi,
> Maybe the commit could be adjusted in Mapserver 7. Out of curiosity, what
> is the use case for zero sized labels and symbols? To disable them, or?
> About the angle, by the Mapserver 7.0 documentation, doesn’t it feel like
> negative angles were not thought to work ever?
> “Angle, given in degrees, to rotate the symbol (counter clockwise).
> Default is 0 (no rotation). If you have an attribute that specifies angles
> in a clockwise direction (compass direction), you have to adjust the angle
> attribute values before they reach MapServer (360-ANGLE), as it is not
> possible to use a mathematical expression for ANGLE.”
> -Jukka Rahkonen-
> *Lähettäjä:* MapServer-users <mapserver-users-bounces at lists.osgeo.org> *Puolesta
> *Oliver Christen
> *Lähetetty:* tiistai 30. toukokuuta 2023 13.59
> *Vastaanottaja:* mapserver-users at lists.osgeo.org
> *Aihe:* [MapServer-users] breaking changes in branch-7-6 after commit of
> Dear Mapserver commiters
> this commit there:
> https://github.com/MapServer/MapServer/pull/6818
> broke a lot of things,
> like style angles not supporting negative values anymore or label size
> mandatorily greater than zero (also possibly for symbol)
> Im not against changes, but changes should be:
> a) documented
> b) announced with preferably a deprecation period
> so, please revert that commit or provide adequate change/documentation for
> all the breaking changes.
> Thank you
> Best regards
> Oliver Christen
> <https://www.camptocamp.com/en/news-events/camptocamp-flagship-office-bussigny>
> *New address from 1st September 2022*
> *Camptocamp SA*
> Route de la Chaux 4
> 1030 Bussigny
> Suisse
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230530/603bd5d2/attachment.htm>
More information about the MapServer-users mailing list
