[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Chris Cantey
cantey0701 at gmail.com
Thu May 4 10:58:35 PDT 2023
No problem: https://pastebin.com/Ssk0cp1b
On Thu, May 4, 2023 at 12:51 PM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> Chris can you paste your latest mapfile at https://pastebin.com/ and
> paste the link here for everyone? (and for any future mailing list
> messages, please use that method, for sharing your mapfile and config
> files)
> thanks,
> -jeff
> On 2023-05-04 2:45 p.m., Chris Cantey wrote:
> > We were also a little concerned about web>template. We didn't see
> > anywhere what exactly we were supposed to put in the TEMPLATE document.
> > its basically the same html document as
> > https://dev.gis.lcc.mn.gov/tmp/mapserver/
> > <https://dev.gis.lcc.mn.gov/tmp/mapserver/> but with <!-- MapServer
> > Template --> on top.
> > CC
> > On Thu, May 4, 2023 at 12:32 PM Chris Cantey <cantey0701 at gmail.com
> > <mailto:cantey0701 at gmail.com>> wrote:
> > I need that t-shirt! The quotes are in the mapfile, I think gmail
> > just hyperlinked the string.
> > I am kind of testing 2 ways: Using the browser(a few methods there),
> > using linux: mapserv
> > "QUERY_STRING=map=/home/map=home/gis/tmp/mapserver/mapserver.map"
> > When I do that, I still get a validation error:
> > [Thu May 4 12:18:06 2023].428388 loadParams() QUERY_STRING:
> > [Thu May 4 12:18:06 2023].428506 msCGILoadMap(): Web application
> > error. CGI variable "map" fails to validate.
> > I'm wondering on the front end if there's a projection issue, I see
> > green network activity: https://dev.gis.lcc.mn.gov/tmp/mapserver/
> > On Thu, May 4, 2023 at 12:29 PM Jeff McKenna
> > <mailto:jmckenna at gatewaygeomatics.com>> wrote:
> > Also, your onlineresource is missing quotes, such as:
> > "wms_onlineresource"
> https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map
> > -jeff
> > Jeff McKenna
> > GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> > co-founder of FOSS4G
> > http://gatewaygeo.com/ <http://gatewaygeo.com/>
> > On 2023-05-04 2:13 p.m., Jeff McKenna wrote:
> > > Thanks. I think you solved any validation issues ( this
> > request would
> > > not validate, for example :
> https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map>
> ) so it's something else, very minor likely (I've got that t-shirt too,
> ha)
> > > -jeff
> > > On 2023-05-04 2:00 p.m., Chris Cantey wrote:
> > >> Thanks, Jeff.. I found that out, thanks.
> > >> I will work down from your points.
> > >> Besc,
> > >> On Thu, May 4, 2023 at 11:57 AM Jeff McKenna
> > <mailto:jmckenna at gatewaygeomatics.com>>>
> > >> wrote:
> > >> Also note, that the regular expression "^" trick applies
> > to the
> > >> MS_MAP_PATTERN in the config file (not the MS_ERRORFILE
> > path in the
> > >> mapfile).
> > >> Thanks for using MapServer Chris,
> > >> -jeff
> > >> -- Jeff McKenna
> > Training
> > <http://gatewaygeo.com/ <http://gatewaygeo.com/>>
> > >> On 2023-05-04 1:48 p.m., Jeff McKenna wrote:
> > >> > More points for your consideration:
> > >> > - make sure all layers have a PROJECTION object
> > >> > - remove any old references to the
> > (non-standard/non-existing)
> > >> > EPSG:900913, replace with EPSG:3857 (see
> > https://epsg.io/3857 <https://epsg.io/3857>
> > >> <https://epsg.io/3857 <https://epsg.io/3857>> )
> > >> > - remove all warnings from your GetCapabilities
> > response, every
> > >> single
> > >> > warning, there should be no warnings in the response,
> > before you
> > >> move to
> > >> > testing GetMap requests
> > >> > - if you have PostGIS/db connections, consider
> > setting EXTENT
> > >> at the
> > >> > layer-level, to improve speed for your clients (review
> > >> optimizations at
> > >> > https://mapserver.org/optimization/vector.html
> > <https://mapserver.org/optimization/vector.html>
> > <https://mapserver.org/optimization/vector.html>> )
> > >> > - during GetMap testing, comment any TEMPLATE params
> > in mapfile
> > >> > -jeff
> > >> _______________________________________________
> > >> MapServer-users mailing list
> > >> MapServer-users at lists.osgeo.org
> > <mailto:MapServer-users at lists.osgeo.org>
> > <mailto:MapServer-users at lists.osgeo.org>>
> > >> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> > <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
> > <https://lists.osgeo.org/mailman/listinfo/mapserver-users>>
> > >> Chris Cantey
> > >> geo-odyssey.com <http://geo-odyssey.com>
> > <http://geo-odyssey.com <http://geo-odyssey.com>>
> > Chris Cantey
> > Chris Cantey
> Jeff McKenna
Chris Cantey
geo-odyssey.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230504/0721a32b/attachment-0001.htm>
More information about the MapServer-users
