[MapServer-users] breaking changes in branch-7-6 after commit of experimental changes from branch-8-0
Oliver Christen
oliver.christen at camptocamp.com
Tue May 30 05:20:32 PDT 2023
before that commit, the following code was working:
STYLE
COLOR 255 255 255
SYMBOL "rectangle3"
ANGLE -45
SIZE 8
GAP 10
END
after that commit, it no longer works, as ANGLE -45 is not accepted
anymore, instead it had to be changed to
STYLE
COLOR 255 255 255
SYMBOL "rectangle3"
ANGLE 315
SIZE 8
GAP 10
END
the documentation https://mapserver.org/mapfile/style.html say it must be
of type DOUBLE, but double can be negative and nothing say explicitly in
the documentation that the value can not be negative.
I see this discussion here:
https://github.com/MapServer/MapServer/issues/6463
but no comment if something was done or agreed on about this.
A note should be added to the documentation to make that clear, as it was
done for label size (see below).
I can do a PR if that would be acceptable ?
for label size, I see that a note was added saying the value must be
greater than zero on 26 january 2022, so I guess this is on me for not
noticing it (but im not alone not noticing it so I guess it wasnt clearly
stated/announced either)
Best regards
Oliver
On Tue, May 30, 2023 at 1:27 PM Rahkonen Jukka <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> Maybe the commit could be adjusted in Mapserver 7. Out of curiosity, what
> is the use case for zero sized labels and symbols? To disable them, or?
> About the angle, by the Mapserver 7.0 documentation, doesn’t it feel like
> negative angles were not thought to work ever?
> “Angle, given in degrees, to rotate the symbol (counter clockwise).
> Default is 0 (no rotation). If you have an attribute that specifies angles
> in a clockwise direction (compass direction), you have to adjust the angle
> attribute values before they reach MapServer (360-ANGLE), as it is not
> possible to use a mathematical expression for ANGLE.”
> -Jukka Rahkonen-
> *Lähettäjä:* MapServer-users <mapserver-users-bounces at lists.osgeo.org> *Puolesta
> *Oliver Christen
> *Lähetetty:* tiistai 30. toukokuuta 2023 13.59
> *Vastaanottaja:* mapserver-users at lists.osgeo.org
> *Aihe:* [MapServer-users] breaking changes in branch-7-6 after commit of
> Dear Mapserver commiters
> this commit there:
> https://github.com/MapServer/MapServer/pull/6818
> broke a lot of things,
> like style angles not supporting negative values anymore or label size
> mandatorily greater than zero (also possibly for symbol)
> Im not against changes, but changes should be:
> a) documented
> b) announced with preferably a deprecation period
> so, please revert that commit or provide adequate change/documentation for
> all the breaking changes.
> Thank you
> Best regards
> Oliver Christen
> <https://www.camptocamp.com/en/news-events/camptocamp-flagship-office-bussigny>
> *New address from 1st September 2022*
> *Camptocamp SA*
> Route de la Chaux 4
> 1030 Bussigny
> Suisse
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230530/2464c758/attachment-0001.htm>
More information about the MapServer-users
