[MapServer-users] How to cascade data from OGC API Features service?
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Tue Nov 14 00:08:31 PST 2023
Oh yes, it was a typo. As a user who tries to be standard compliant I had upgraded the name in one place to match with the OGC approved abbreviation “OGCFeat” instead of the GDAL driver name “OAPIF”.
The MAXSCALEDENOM value 60000 (naturally copy-pasted from some old mapfile) is all too large for that service in areas with lots of buildings. Scale 1:5000 is probably safe everywhere. A EPSG:3067 bbox for testing:
BBOX=390723,6671479,392177,6672231
Positive thing is that now also other Mapserver users know that it is possible to use OGCFeat services as source data with OGR connection. Thanks to you and TC Haddad who also found the typo.
-Jukka Rahkonen-
Lähettäjä: Richard Greenwood <richard.greenwood at gmail.com>
Lähetetty: tiistai 14. marraskuuta 2023 5.38
Vastaanottaja: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Kopio: Mapserver-Users (mapserver-users at lists.osgeo.org) <mapserver-users at lists.osgeo.org>
Aihe: Re: [MapServer-users] How to cascade data from OGC API Features service?
Are you sure that you don't just have a typo? Your file is named "ogcfeat.vrt" but your CONNECTION "c:/ms4w_data/oapif.vrt"
I set up a quick test and I haven't gotten a map (it timed out 504 error after several minutes) but I didn't get an error. Maybe you could share a smaller test data set and a reasonable bounding box. My test:
http://localhost/cgi-bin/mapserv?map=MAP_TEST&REQUEST=GetMap&SERVICE=WMS&VERSION=1.3.0&LAYERS=building&WIDTH=696&HEIGHT=870&CRS=EPSG:3067&BBOX=-359700,6615190,-359500,6615199&FORMAT=png
On Mon, Nov 13, 2023 at 2:48 PM Rahkonen Jukka via MapServer-users <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>> wrote:
I tried to make a WMS layer from OGC API Features service but I did not success. This is my best trial so far:
I am using Mapserver from MS4W 5.0.0 RC1
I wrote this ORG VRT file (ogcfeat.vrt)
<OGRVRTDataSource>
<OGRVRTLayer name="building">
<SrcDataSource>OAPIF:https://beta-paikkatieto.maanmittauslaitos.fi/inspire-buildings/features/v1/</SrcDataSource>
<SrcLayer>building</SrcLayer>
</OGRVRTLayer>
</OGRVRTDataSource>
The GDAL included in MS4W reads the vrt OK with
ogrinfo ogcfeat.vrt -al -so --debug on
(there are 5 millions polygons so hit Ctrl-C if you are just testing)
I wrote a layer that can be at the bottom of this message below. The WMS GetCapabilities show the new layer but GetMaps fail. The log file collects these errors
msDrawMap(): Image handling error. Failed to draw layer named 'building'.
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `building'. File not found or unsupported format. Check server logs.
Am I missing something from my configuration? My LAYER is like this
LAYER
NAME "building"
STATUS ON
CONNECTIONTYPE OGR
DATA "building"
TYPE POLYGON
# DEBUG 5
UNITS METERS
SIZEUNITS PIXELS
MAXSCALEDENOM 60000
TOLERANCE 3
TOLERANCEUNITS PIXELS
METADATA
"wms_title" "OGCFeat-building"
"wms_include_items" "all"
END #metadata
PROJECTION
"init=epsg:3067" ##recommended
END
CLASS
NAME "building"
STYLE
COLOR 200 255 200
OUTLINECOLOR 120 120 120
END # Style
END # Class
TEMPLATE "empty" ##recommended (enable GetFeatureInfo / can point to valid .html template)
END # Layer
-Jukka Rahkonen-
MapServer-users mailing list
MapServer-users at lists.osgeo.org<mailto:MapServer-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
Richard W. Greenwood
www.greenwoodmap.com<http://www.greenwoodmap.com/>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231114/3f310307/attachment.htm>
More information about the MapServer-users
