[MapServer-users] I want to change Map
Sven Schroeter schroeter at netgis.de
Mon Nov 27 23:16:56 PST 2023
Tile-based maps are provided in a predefined tileset. In the case of
Google or OSM, for example, this is usually in EPSG 3857 and is defined
in a grid with corresponding resolutions for the different zoom levels
(always based on an extent):
https://mapserver.org/mapcache/config.html#preconfigured-grids
A WMS is usually used as the data source.
Of course, you can also do this for self-defined tilesets with other
resolutions and extents, as in the case of the Korean institute.
With MS4W and the Mapcache software it contains, you can define and
create such a tileset yourself.
Greetings from Germany
Sven
Am 28.11.2023 um 02:00 schrieb 최종호 via MapServer-users:
> Hello everyone.!
> Good morning.
> I'm Choi and I'm Korean.
> I'm trying to load and manage a map.
> 1. I found mapwingis for C#
> 2. I found video for sample
> https://www.youtube.com/watch?v=mBu9XgrfZfM
>     In this video, he gets map images with SAS.planet program and
> supplies maps with ms4w.
>     After, he loaded the maps in C# project with axmap.
> 3. I did the sample and it works well.
> 4. It will take about 200 days to get 20 level's maps with SAS.planet
> program for some area)
> 5. So, I got new maps about 4TB from https://www.ngii.go.kr/ is
> Korea's National Geographic Information Institute
> 6. But, I failed to load the new map in sample c# project
>     // Source code used in video C# project
>     providers.Add(providerid, "map", "http://127.0.0.1/map/z{zoom}/
> <http://127.0.0.1/map/z{zoom}/>*{y}/{x}*.png",
> tkTileProjection.SphericalMercator, 0, 13);
>     // Modified Source code
>     providers.Add(providerid, "map", "http://127.0.0.1/map1/z{zoom}/
> <http://127.0.0.1/map1/z{zoom}/>*{x}/{y}*.png",
> 7. After I found some differences.
>     - Sample's map is Google map based EPSG:4326 and file's array is
> {zoom}{y}{x} and image's size 256*256 pixels
>     - But my new maps are based EPSG:5179 and files array is
> {zoom}[x]{y} and image's size
> 512*512 pixels
> If someone knows the way to load my new maps with ms4w
> Please, let me know.
> Thank you!
> Best regards
> Choi.
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231128/d94c7110/attachment.htm>
More information about the MapServer-users mailing list
