[MapServer-users] Cluster with Oracle Spatial data
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Oct 10 12:12:12 PDT 2023
Hi Ivan,
I believe this should work with any database or OGR connection (I think
my initial tests, for the docs, were with an OGR/KML connection, but I
remember testing SpatiaLite later as well for cluster).
(I'll see if I can test this with Oracle, but, it may take me a while to
setup, so someone else might have to jump in & help you here)
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
On 2023-10-10 10:50 a.m., Yankov, Ivan via MapServer-users wrote:
> Hi,
> I have a problem with clustering a point layer (combine multiple
> features into a single feature based on their relative positions)
> using a point datasource from an Oracle Spatial Database.
> When I test the cluster feature using a point layer in Shape-Format, it
> works exactly as expected.
> In this case I use “DATA " D:\geodata\point_layer.shp" “ as my
> datasource and everything works just fine.
> But when I change the datasource to “ CONNECTIONTYPE oraclespatial “ and
> then use the same point layer
> from the Oracle Spatial Database, then nothing actually happens. I don’t
> even get some kind of an error message.
> Does anyone know the reason for this behaviour and how can I get the
> cluster feature to work with an Oracle Spatial datasource?
> Thank you in advance!
> Best Regards
More information about the MapServer-users
