[MapServer-users] symbol minsize/maxsize in mapServer 8
Seth G
sethg at geographika.co.uk
Wed Oct 11 12:36:18 PDT 2023
Hi Jörg,
The STYLE MINSIZE and MAXSIZE are still valid Mapfile keywords - this was an error in the docs (and also came up on the dev list yesterday. This has now been corrected and the online docs fixed.
I'm equally as confused as how exactly to use these. In your example what is your SYMBOL definition for "circle"?
I've not seen the OpenLayers template used for awhile - if could do with an upgrade to OL7!
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Wed, Oct 11, 2023, at 5:06 PM, Jörg Thomsen (WhereGroup) via MapServer-users wrote:
> Hello,
> I am curious about min- an maxsize in MS 8.
> I found in the docs:
>> MAXSIZE [double]
>> Removed in version 8.0.
> And I know don't now how to determine the maxsize of a point Symbol.
> maxsize still works, but not as expected. There is no error-message and
> the maxsize auf the point-symbol is set, but when I zoom in more than
> the scale of SYMBOLSCALEDENOM the outline of the symbol ist getting and
> bigger.
> Here are two layers I tested with and you can test the WMS with
> https://schulung.foss.academy/cgi-bin/mapserv?map=minmaxsize&mode=browse&template=openlayers&layer=all
> (you have to zoom in to see what happens)
> LAYER
> NAME 'point'
> TYPE POINT
> DATA 'pois_p.shp'
> METADATA
> 'ows_title' 'Points'
> END
> SYMBOLSCALEDENOM 100000
> CLASS
> NAME 'points'
> STYLE
> SYMBOL 'circle'
> SIZE 20
> COLOR 218 247 195
> OUTLINECOLOR 250 250 0
> END
> END
> END
> LAYER
> NAME 'pointmaxsize'
> TYPE POINT
> DATA 'pois_p.shp'
> METADATA
> 'ows_title' 'Pointsmaxsize'
> END
> CLASS
> NAME 'points'
> STYLE
> SYMBOL 'circle'
> SIZE 20
> MAXSIZE 30
> COLOR 100 100 250
> OUTLINECOLOR 0 0 250
> END
> END
> END
> Viele Grüße,
> Jörg Thomsen
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Tel: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> joerg.thomsen at wheregroup.com
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
