[MapServer-users] symbol minsize/maxsize in mapServer 8
Seth G sethg at geographika.co.uk
Wed Oct 11 13:09:09 PDT 2023
Hi Jörg,
I've been playing around with the MINSCALE etc. When using an OUTLINECOLOR you also need to set the MINWIDTH and MAXWIDTH on the SYMBOL to change sizes with resolution. I think this is the issue you were seeing in your example.
For example to keep a constant outline width of 1 you can use the following:
STYLE
    SYMBOL "circle"
    SIZE 100
    MAXSIZE 200
    MINSIZE 12
    COLOR "#F9A03F"
    OUTLINECOLOR "#813405"
    MINWIDTH 1
    MAXWIDTH 1
END
There is a working example at https://app.mapserverstudio.net/#akyRvQvW - if you zoom in you will notice the circles get bigger (up to 200 pixels) but the outline width remains at 1 pixel.
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Wed, Oct 11, 2023, at 5:06 PM, Jörg Thomsen (WhereGroup) via MapServer-users wrote:
> Hello,
> I am curious about min- an maxsize in MS 8.
> I found in the docs:
>> MAXSIZE [double]
>> Removed in version 8.0.
> And I know don't now how to determine the maxsize of a point Symbol.
> maxsize still works, but not as expected. There is no error-message and
> the maxsize auf the point-symbol is set, but when I zoom in more than
> the scale of SYMBOLSCALEDENOM the outline of the symbol ist getting and
> bigger.
> Here are two layers I tested with and you can test the WMS with
> https://schulung.foss.academy/cgi-bin/mapserv?map=minmaxsize&mode=browse&template=openlayers&layer=all
> (you have to zoom in to see what happens)
>     LAYER
>        NAME 'point'
>        TYPE POINT
>        DATA 'pois_p.shp'
>        METADATA
>          'ows_title' 'Points'
>        END
>        SYMBOLSCALEDENOM 100000
>        CLASS
>          NAME 'points'
>          STYLE
>            SYMBOL 'circle'
>            SIZE 20
>            COLOR 218 247 195
>            OUTLINECOLOR 250 250 0
>          END
>        END
>      END
>      LAYER
>        NAME 'pointmaxsize'
>        TYPE POINT
>        DATA 'pois_p.shp'
>        METADATA
>          'ows_title' 'Pointsmaxsize'
>        END
>        CLASS
>          NAME 'points'
>          STYLE
>            SYMBOL 'circle'
>            SIZE 20
>            MAXSIZE 30
>            COLOR 100 100 250
>            OUTLINECOLOR 0 0 250
>          END
>        END
>      END
> Viele Grüße,
> Jörg Thomsen
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Tel: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> joerg.thomsen at wheregroup.com
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
