[MapServer-users] Cluster with Oracle Spatial data
Yankov, Ivan YankovI at eba.bund.de
Thu Oct 12 00:02:56 PDT 2023
Hi Holger,
thanks for your feedback. All my services use the Oracle Spatial database, so there is no problem with the general connection to the database.
Its just that the cluster option doesn’t work for me when I use Oracle as datasource.
The shape-layer that I described was only for test purposes because I wanted to see if I can get the cluster feature working at all.
There seemed to be no issues with a shape source. The problem occurs only when I use my default datasource, which in my case is Oracle Spatial.
Regards
Ivan
-----Ursprüngliche Nachricht-----
Von: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Im Auftrag von Holger Schiebold via MapServer-users
Gesendet: Mittwoch, 11. Oktober 2023 10:08
An: mapserver-users at lists.osgeo.org
Betreff: Re: [MapServer-users] Cluster with Oracle Spatial data
Yes, that should not be a problem with oracle spatial and cluster.
Generally this works.
(https://via.bund.de/wsv/wadaba/www/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.3.0)
This service works with cluster and oracle spatial data. ( an older service and a bit slow - the problem we had with cluster option and some more features was primarily the performance) I would test if your oracle features are shown without cluster option first. Maybe it's a problem with your oracle connection setup first.
regards Holger
Am 10.10.2023 um 21:12 schrieb Jeff McKenna via MapServer-users:
> Hi Ivan,
> I believe this should work with any database or OGR connection (I
> think my initial tests, for the docs, were with an OGR/KML connection,
> but I remember testing SpatiaLite later as well for cluster).
> (I'll see if I can test this with Oracle, but, it may take me a while
> to setup, so someone else might have to jump in & help you here)
> -jeff
mit freundlichen Grüßen
Holger Schiebold
____________________
codematix GmbH
Felsbachstrasse 5/7
D-07745 Jena
Tel. +49 (3641) 3038-18
www.codematix.de
MapServer-users mailing list
MapServer-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
