[MapServer-users] creating a layer with PHP MapScript - shapes do not use classindex
Worth Lutz
wal3 at mindspring.com
Mon Oct 16 05:57:37 PDT 2023
I had thought of trying that but the attributes in the values are
read-only. Since i created the shapeObj from WTK there are no values.
I'm using v7 of MapServer and the old PHP mapscript. There does not
appear to be a way for me to set attributes on these shapes which are
being passed down from an OpenLayers client app.
I had thought of setting a single class and putting the different
colors, etc, in as attribute values in the shapeObj but cannot find a
way to write them to the object.
I'll try any suggestions given.
Thanks,
*Worth Lutz*
On 10/16/23 03:59, Seth G wrote:
> Hi,
> The rendering code could be reassigning the classindex for the shapes
> based on their attributes. You will probably need to make sure the
> CLASS is assigned based on an attribute of the feature - e.g. add a
> CLASSITEM to the layer and add a value to the feature that will match
> the correct CLASS.
> Seth
> web:https://geographika.net & https://mapserverstudio.net
> twitter: @geographika
> On Sun, Oct 15, 2023, at 3:12 PM, Worth Lutz via MapServer-users wrote:
>> HI,
>> I'm trying to create a layer to insert into a map. I have shapes in
>> WKT and am trying to insert them into a layer and draw it to a pdf.
>> It works fine if I only have one class for the shapes. I am trying to
>> add several classes to the layer to draw in different colors. I
>> cannot get the shapes to use the proper class.
>> Here is what I'm doing.
>> After creating a layer and adding all the classes, I add the shapes.
>> for (i = 0, ii = count($features); $i < $ii; i++) {
>> $shape = ms_shhapeObjFrom Wkt($features[$i]->geometry);
>> $shape->set('classindex', $features[$i]->classindex);
>> $success = $layer->addFeature($shape);
>> The shapes draw but all use $class[0].
>> If I add this line in before the draw,
>> $layer-moveclassup(1);
>> all the shapes are drawn with that class.
>> I have been able to verify that the classes exist in the layerObj and
>> that the classindex in the shapeObj points to the proper class.
>> Does anyone have any ideas why the drawing code is not using the
>> classindex to draw these shapes in different colors?
>> What am I doing wrong?
>> *Worth Lutz*
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231016/0fe68201/attachment.htm>
More information about the MapServer-users
