[MapServer-users] Compiling mapserver with php in user directory
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Oct 18 10:11:50 PDT 2023
Hi Jan,
I understand that you won't listen to my advice here, no problem at all.
  But I won't repeat myself here :)
Enjoy your afternoon,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
On 2023-10-18 1:39 p.m., Jan Hartmann wrote:
> I compiled with:
>   -DPHP_INCLUDE_DIR=$INSTALLBIN/include/php \
>   -DPHP_EXTENSION_DIR=$INSTALLBIN/lib/php/extensions/no-debug-non-zts-20220829
> and got lots of error messages about missing .h files (php.h, zend.h
> etc). I bulk copied them all to the directory in the build tree where
> the errors came from, and got a complete build, including
> "php_mapscriptng.so"
> So CMAKE is still missing the php include directories. What is de
> correct DEFINE for that?
> After I copied php_mapscriptng.so to the correct location and filling in
> php.ini, I got a warning when starting PHP :
> Startup: Unable to load dynamic library 'php_mapscriptng.so' (tried:
> /virdir/installbin/lib/php/extensions/no-debug-non-zts-20220829/php_mapscriptng.so (libgeos.so.3.12.0: cannot open shared object file: No such file or directory)
> But  it *is* in that location. Any idea?
> On 17/10/2023 21:45, Jeff McKenna via MapServer-users wrote:
>> Hi Jan,
>> Unfortunately I have much experience tracking down CMake errors now, ha.
>> Instead of the error log, scroll up and read the output from your
>> cmake command (as it does its checks and looks for libraries), I find
>> examining that output is crucial (and I personally find the actual
>> generated log file is filled of fake/"red-herrings"). Focus instead on
>> going line-by-line through that cmake output, as it makes its way down
>> to the final "configuring incomplete" message.  (for packaging, this
>> is what I do, line-by-line)
>> For example, if you are trying to enable the GEOS library, I would go
>> line-by-line of the output and find where it was looking for GEOS
>> initially, and read the messages in that section, to confirm that
>> there are no issues when enabling GEOS.  This is crucial.
>> It takes much time to do this for each library.
>> In my case, for PHPNG support, my CMake command includes:
>> "-DWITH_PHPNG=1 -DPHP_EXTENSION_DIR=/usr/lib/php/20220829"
>> In your case I am not sure, but, I would start by examining
>> line-by-line the CMake output before the words "Configuring
>> incomplete" (and totally ignoring the generated 'output' file).
>> Maybe you can find the PHPNG section in your cmake command output, and
>> paste that here for the community to review.
>> -jeff
More information about the MapServer-users mailing list
