[MapServer-users] Postgres DATA query with LIMIT 10 does not work
Marcin Niemyjski
mniemyjski at cloudferro.com
Thu Oct 19 03:56:40 PDT 2023
hello Jörg,
so, If there's fewer than 10 results, none will be rendered? I taught that LIMIT sets only upper border of results count.
and yup, I've just checked it:
SELECT *
FROM (
SELECT *
FROM mrc
WHERE mrc.timestamp >= '2023-08-01' AND mrc.timestamp <= '2023-08-01'
AND ST_Intersects(mrc.geometry, ST_GeomFromText('POLYGON((2791286.85068837 5622573.79066471,2791286.85068837 5638166.03910615,2805874.3941497 5638166.03910615,2805874.3941497 5622573.79066471,2791286.85068837 5622573.79066471))', 3857))
ORDER BY maxcc DESC
) AS subquery;
query results in only 2 records.
Is there any way to get only 10 or less results using postgis query in mapserver?
Best,
Marcin
[cid:3c4ade68-ed3d-4e2c-a9eb-ad74db8b6632]<https://outlook.office.com/bookwithme/user/6347c7def05a478ba013ae948648789d@cloudferro.com?anonymous&ep=signature> Book time to meet with me<https://outlook.office.com/bookwithme/user/6347c7def05a478ba013ae948648789d@cloudferro.com?anonymous&ep=signature>
From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> on behalf of Jörg Thomsen (WhereGroup) via MapServer-users <mapserver-users at lists.osgeo.org>
Sent: Thursday, October 19, 2023 12:18 PM
To: mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
Subject: Re: [MapServer-users] Postgres DATA query with LIMIT 10 does not work
Hello Marcin,
sounds stupid, but are you sure the 10 datasets have geometries within
the requested bbox? I don't see any other problem/mistakes.
Jörg
Am 19.10.23 um 11:39 schrieb Marcin Niemyjski via MapServer-users:
> Hello,
> I encountered a problem, specifically:
> This query works:
> |DATA 'geometry from (select * from mrc order by maxcc desc) as subquery
> using unique unique_id' |
> However, this query doesn't work:
> |DATA 'geometry from (select * from mrc order by maxcc desc limit 10) as
> subquery using unique unique_id' |
> Here's the full tileindex definition:
> |LAYER DEBUG 5 STATUS OFF NAME "time_idx" TYPE POLYGON
> CONNECTIONTYPE postgis CONNECTION "***" DATA 'geometry from (select
> * from mrc order by maxcc desc limit 10) as subquery using unique
> unique_id' PROJECTION "init=epsg:3857" END VALIDATION 'maxCC'
> '^[0-9]{1,3}$' 'default_maxCC' '100' END METADATA "wms_title"
> "tile-index-cloud" "wms_timeextent" "2022-02-01/2023-10-10/P1D"
> "wms_timeitem" "timestamp" "wms_timedefault" "2023-10-10"
> "wms_enable_request" "!*" END END |
> My MapServer version is 7.6.4.
> The query results (but returns data in Postgres
> ) in an empty window. I'm following the guidelines provided at
> https://mapserver.org/input/vector/postgis.html#data-access-connection-method <https://mapserver.org/input/vector/postgis.html#data-access-connection-method>.
> Best,
> marcin
> <https://outlook.office.com/bookwithme/user/6347c7def05a478ba013ae948648789d@cloudferro.com?anonymous&ep=signature> Book time to meet with me <https://outlook.office.com/bookwithme/user/6347c7def05a478ba013ae948648789d@cloudferro.com?anonymous&ep=signature>
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com<http://www.foss-academy.com>
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
joerg.thomsen at wheregroup.com
www.wheregroup.com<http://www.wheregroup.com>
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231019/2f71d199/attachment.htm>
Type: image/png
Desc: Outlook-xjeacwcn.png
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231019/2f71d199/attachment.png>
More information about the MapServer-users
