[MapServer-users] Docker image for MapServer with PHP-MapScript
    Jan Hartmann
    j.l.h.hartmann at gmail.com
    Sat Oct 28 11:13:49 PDT 2023
This seems to work.  And it says so in the migration guide
(https://mapserver.org/mapscript/php/migration_guide.html):
all of your PHP scripts (that leverage MapServer objects and functions)
must now always first include the generatedmapscript.phpfile containing
MapServer constants:
But could it be that only "$m = new mapObj('...');" is accepted, and
"$m=ms_newMapObj('...');" isn't? The docs still mention the old call
(https://mapserver.org/mapscript/php/phpmapscript.html
On 28/10/2023 09:11, Vassilis Chatzigiannakis wrote:
> Hi,
> I did it recently. There should be a mapscript.php file in the same
> folder as the  php_mapscriptng.so extension.
> You need to include it in your php script.
> Best,
> Vassilis
> *From:* MapServer-users <mapserver-users-bounces at lists.osgeo.org> *On
> Behalf Of *Jan Hartmann via MapServer-users
> *Sent:* Friday, October 27, 2023 9:42 PM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [MapServer-users] Docker image for MapServer with
> PHP-MapScript
> I made a docker version of mapserver/php-mapscript myself, based on
> Ubuntu 22.04. I installed all required libraries with apt, and
> compiled mapserver and mapscript according to instructions. No problem
> at all.
> At the end I got the following from phpinfo();
>     mapscript
> *MapServer Version*
> MapServer version 8.0.1 PROJ version 9.3 GDAL version 3.4 OUTPUT=PNG
> OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=OGCAPI_SERVER SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE INPUT=FLATGEOBUF
> But no mapscript function or object was regognized in my PHP-scripts:
> PHP Fatal error:  Uncaught Error: Class "mapObj" not found in
> /virdir/www_root/test.php:2
> Stack trace:
> #0 {main}
>   thrown in /virdir/www_root/test.php on line 2
> I am really desparate. Has anyone ever succeeded to get
> php_mapscriptng.so to work?  Or does anyone know of a working Docker
> image for MapServer with PHP MapScript?
> Jan
> On 21/10/2023 05:40, Jan Hartmann wrote:
>     I tried this with serveral versions of PHP and MapServer, but got
>     always the same result. Can anyone point me to a Docker image for
>     MapServer + PHP-MapScript?
>     Jan
>     On 19/10/2023 18:12, Jan Hartmann wrote:
>         Still not there. Everything has been installed, and phpinfo()
>         gives:
>         *MapServer Version*
>         MapServer version 8.0.1 PROJ version 9.3 GDAL version 3.7
>         OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG
>         SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER
>         SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>         SUPPORTS=WCS_SERVER SUPPORTS=OGCAPI_SERVER INPUT=JPEG
>         INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>         INPUT=FLATGEOBUF
>         But calling "$map = new mapObj('mapfile.map');" gives:
>         *Fatal error*: Uncaught Error: Class "mapObj" not found in
>         /mnt/virdir/www_root/test/test_mapscript.php:2 Stack trace: #0
>         {main} thrown in
>         */mnt/virdir/www_root/test/test_mapscript.php* on line *2
>         *Any idea?
>         Jan
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231028/65ea168c/attachment.htm>
More information about the MapServer-users
