[MapServer-users] Compiling mapserver with php in user directory
Jan Hartmann j.l.h.hartmann at gmail.com
Thu Oct 19 08:55:33 PDT 2023
Hi Jeff, I appreciate your advice, but I solved the problem with a hack,
and to be honest, CMAKE error handling is above me. I am still from the
./configure generation :-)
I added these two lines to MapServer's CMAKE call:
  -DPHP_INCLUDE_PATH=$INSTALLBIN/include/php/main \
-DPHP_EXTENSION_DIR=$INSTALLBIN/lib/php/extensions/no-debug-non-zts-20220829
I also had to add these lines to GEOS's CMAKE, after
-DCMAKE_INSTALL_PREFIX=$INSTALLBIN  -DCMAKE_PREFIX_PATH=$INSTALLBIN \
-DCMAKE_LIBRARY_PATH=$INSTALLBIN/lib \
-DINCLUDE_DIRECTORIES=$INSTALLBIN/include \
I guess CMAKE does not propagate its dependencies very well from the
general INSTALL_PREFIX.
But this still didn't work. The php includes in other subdirectories
than main weren't found. Those subdirectories should have been added to
the include path, but weren't. So I copied the complete php include
directory to /usr/include (O horror! :-)) .
Of course a Docker installation would be easier, as you can install
everything in standard locations. But I want to have a real dedicated
server with just the software I need and nothing more. I have worked for
a long time with the UbuntuGIS packages, but they are not supported very
well.
Thanks for your advice!
Jan
On 18/10/2023 19:11, Jeff McKenna via MapServer-users wrote:
Hi Jan,
I understand that you won't listen to my advice here, no problem at all.
  But I won't repeat myself here 🙂
Enjoy your afternoon,
-jeff
> On 2023-10-18 1:39 p.m., Jan Hartmann wrote:
>> I compiled with:
>>   -DPHP_INCLUDE_DIR=$INSTALLBIN/include/php \
>> and got lots of error messages about missing .h files (php.h, zend.h
>> etc). I bulk copied them all to the directory in the build tree where
>> the errors came from, and got a complete build, including
>> "php_mapscriptng.so"
>> So CMAKE is still missing the php include directories. What is de
>> correct DEFINE for that?
>> After I copied php_mapscriptng.so to the correct location and filling
>> in php.ini, I got a warning when starting PHP :
>> Startup: Unable to load dynamic library 'php_mapscriptng.so' (tried:
>> /virdir/installbin/lib/php/extensions/no-debug-non-zts-20220829/php_mapscriptng.so
>> (libgeos.so.3.12.0: cannot open shared object file: No such file or
>> directory)
>> But  it *is* in that location. Any idea?
>> On 17/10/2023 21:45, Jeff McKenna via MapServer-users wrote:
>>> Hi Jan,
>>> Unfortunately I have much experience tracking down CMake errors now,
>>> ha.
>>> Instead of the error log, scroll up and read the output from your
>>> cmake command (as it does its checks and looks for libraries), I
>>> find examining that output is crucial (and I personally find the
>>> actual generated log file is filled of fake/"red-herrings"). Focus
>>> instead on going line-by-line through that cmake output, as it makes
>>> its way down to the final "configuring incomplete" message.  (for
>>> packaging, this is what I do, line-by-line)
>>> For example, if you are trying to enable the GEOS library, I would
>>> go line-by-line of the output and find where it was looking for GEOS
>>> initially, and read the messages in that section, to confirm that
>>> there are no issues when enabling GEOS.  This is crucial.
>>> It takes much time to do this for each library.
>>> In my case, for PHPNG support, my CMake command includes:
>>> "-DWITH_PHPNG=1 -DPHP_EXTENSION_DIR=/usr/lib/php/20220829"
>>> In your case I am not sure, but, I would start by examining
>>> line-by-line the CMake output before the words "Configuring
>>> incomplete" (and totally ignoring the generated 'output' file).
>>> Maybe you can find the PHPNG section in your cmake command output,
>>> and paste that here for the community to review.
>>> -jeff
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231019/bb018695/attachment.htm>
More information about the MapServer-users mailing list
