[MapServer-users] Mapserver 8 , PHP map script cannot print image
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Oct 26 05:01:36 PDT 2023
Hi Vassilis,
You are missing after the draw() the following:
   //send image to stdout (browser), without saving file locally
   echo $oImage ->getBytes();
I also prefer to set the header right before that getBytes() call.
For a full working example, you can use the quickmap.php file that is
included in MS4W (see /ms4w/Apache/htdocs/quickmap.php) from
https://ms4w.com
Hope that helps,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
On 2023-10-26 7:25 a.m., Vassilis Chatzigiannakis via MapServer-users wrote:
> Dear all,
> We are using Mapserver 8.0.1 with PHP and the php_mapscriptng extension.
> I am having a hard time outputting the image to the browser.
> In the following code snippet, saving to disk works but
> mapscript.imageObj.write does not output the image in the browser.
> header('Content-type: image/png');
> $oImg=$oMap->draw();
> $oImg->save("/tmp/mswms.png");
> $oImg->write();
> Do you have a working PHP example of
> https://mapserver.org/mapscript/mapscript-api/stub/mapscript.imageObj.html#mapscript.imageObj.write <https://mapserver.org/mapscript/mapscript-api/stub/mapscript.imageObj.html#mapscript.imageObj.write>?
> Or is there another way of showing the image in the browser?
> Best regards,
> Vassilis
More information about the MapServer-users mailing list
