[MapServer-users] Docker image for MapServer with PHP-MapScript
Vassilis Chatzigiannakis vchatzi at itml.gr
Sat Oct 28 00:11:13 PDT 2023
I did it recently. There should be a mapscript.php file in the same folder as the  php_mapscriptng.so extension.
You need to include it in your php script.
Best,
Vassilis
From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> On Behalf Of Jan Hartmann via MapServer-users
Sent: Friday, October 27, 2023 9:42 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [MapServer-users] Docker image for MapServer with PHP-MapScript
I made a docker version of mapserver/php-mapscript myself, based on Ubuntu 22.04. I installed all required libraries with apt, and compiled mapserver and mapscript according to instructions. No problem at all.
At the end I got the following from phpinfo();
mapscript
MapServer Version
MapServer version 8.0.1 PROJ version 9.3 GDAL version 3.4 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=OGCAPI_SERVER SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE INPUT=FLATGEOBUF
But no mapscript function or object was regognized in my PHP-scripts:
PHP Fatal error:  Uncaught Error: Class "mapObj" not found in /virdir/www_root/test.php:2
Stack trace:
#0 {main}
  thrown in /virdir/www_root/test.php on line 2
I am really desparate. Has anyone ever succeeded to get php_mapscriptng.so to work?  Or does anyone know of a working Docker image for MapServer with PHP MapScript?
Jan
On 21/10/2023 05:40, Jan Hartmann wrote:
I tried this with serveral versions of PHP and MapServer, but got always the same result. Can anyone point me to a Docker image for MapServer + PHP-MapScript?
Jan
On 19/10/2023 18:12, Jan Hartmann wrote:
Still not there. Everything has been installed, and phpinfo() gives:
MapServer Version
MapServer version 8.0.1 PROJ version 9.3 GDAL version 3.7 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=OGCAPI_SERVER INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE INPUT=FLATGEOBUF
But calling "$map = new mapObj('mapfile.map');" gives:
Fatal error: Uncaught Error: Class "mapObj" not found in /mnt/virdir/www_root/test/test_mapscript.php:2 Stack trace: #0 {main} thrown in /mnt/virdir/www_root/test/test_mapscript.php on line 2
Any idea?
Jan
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231028/30dae8e4/attachment.htm>
More information about the MapServer-users mailing list
