[MapServer-users] Docker image for MapServer with PHP-MapScript
Jan Hartmann j.l.h.hartmann at gmail.com
Mon Oct 30 10:45:46 PDT 2023
Almost there. There are additional migration examples in:
https://ms4w.com/trac/wiki/MigrationGuide5.x
I wrote wrapper functions for the old ms_new... functions, and can
create that way a new mapObj called $oMap.
The "set" function has been  renamed  to "__set" : not
$oMap->set("maxsize",6020), but: ;$oMap->__set("maxsize",6020);
Layers can be declared as before:  $layer = $oMap->getLayer(1).
Metadata have to be set as follows:
Not: $layer->setMetadata("...","..."); but:
$layer->metadata->set("...","...")
However, I cannot set the metadata of the mapObj:
$oMap->metadata->set("...","...") gives: "Undefined array key "metadata""
Any idea?
On 29/10/2023 07:52, Vassilis Chatzigiannakis wrote:
> Yes the documentation is a mess .
> I worked with this reference:
> https://mapserver.org/mapscript/mapscript-api/index.html
> So, you start by
> $oMap= newmapObj($mapfile);
> Best regards,
> Vassilis
> *From:* Jan Hartmann <j.l.h.hartmann at gmail.com>
> *Sent:* Saturday, October 28, 2023 9:14 PM
> *To:* Vassilis Chatzigiannakis <vchatzi at itml.gr>;
> mapserver-users at lists.osgeo.org
> *Subject:* Re: [MapServer-users] Docker image for MapServer with
> PHP-MapScript
> This seems to work.  And it says so in the migration guide
> (https://mapserver.org/mapscript/php/migration_guide.html):
> all of your PHP scripts (that leverage MapServer objects and
> functions) must now always first include the generated
> mapscript.php file containing MapServer constants:
> But could it be that only "$m = new mapObj('...');" is accepted, and
> "$m=ms_newMapObj('...');" isn't? The docs still mention the old call
> (https://mapserver.org/mapscript/php/phpmapscript.html
> On 28/10/2023 09:11, Vassilis Chatzigiannakis wrote:
>     Hi,
>     I did it recently. There should be a mapscript.php file in the
>     same folder as the  php_mapscriptng.so extension.
>     You need to include it in your php script.
>     Best,
>     Vassilis
>     *From:* MapServer-users <mapserver-users-bounces at lists.osgeo.org>
>     <mailto:mapserver-users-bounces at lists.osgeo.org> *On Behalf Of
>     *Jan Hartmann via MapServer-users
>     *Sent:* Friday, October 27, 2023 9:42 PM
>     *To:* mapserver-users at lists.osgeo.org
>     PHP-MapScript
>     I made a docker version of mapserver/php-mapscript myself, based
>     on Ubuntu 22.04. I installed all required libraries with apt, and
>     compiled mapserver and mapscript according to instructions. No
>     problem at all.
>     At the end I got the following from phpinfo();
>         mapscript
>     *MapServer Version*
>     MapServer version 8.0.1 PROJ version 9.3 GDAL version 3.4
>     OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG
>     SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER
>     SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>     SUPPORTS=WCS_SERVER SUPPORTS=OGCAPI_SERVER SUPPORTS=GEOS
>     INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>     INPUT=FLATGEOBUF
>     But no mapscript function or object was regognized in my PHP-scripts:
>     PHP Fatal error:  Uncaught Error: Class "mapObj" not found in
>     /virdir/www_root/test.php:2
>     Stack trace:
>     #0 {main}
>       thrown in /virdir/www_root/test.php on line 2
>     I am really desparate. Has anyone ever succeeded to get
>     php_mapscriptng.so to work?  Or does anyone know of a working
>     Docker image for MapServer with PHP MapScript?
>     Jan
>     On 21/10/2023 05:40, Jan Hartmann wrote:
>         I tried this with serveral versions of PHP and MapServer, but
>         got always the same result. Can anyone point me to a Docker
>         image for MapServer + PHP-MapScript?
>         Jan
>         On 19/10/2023 18:12, Jan Hartmann wrote:
>             Still not there. Everything has been installed, and
>             phpinfo() gives:
>             *MapServer Version*
>             MapServer version 8.0.1 PROJ version 9.3 GDAL version 3.7
>             SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>             SUPPORTS=OGCAPI_SERVER INPUT=JPEG INPUT=POSTGIS INPUT=OGR
>             INPUT=GDAL INPUT=SHAPEFILE INPUT=FLATGEOBUF
>             But calling "$map = new mapObj('mapfile.map');" gives:
>             *Fatal error*: Uncaught Error: Class "mapObj" not found in
>             /mnt/virdir/www_root/test/test_mapscript.php:2 Stack
>             trace: #0 {main} thrown in
>             */mnt/virdir/www_root/test/test_mapscript.php* on line *2
>             *Any idea?
>             Jan
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231030/eaeb8656/attachment.htm>
More information about the MapServer-users mailing list
