[MapServer-users] Cannot retrieve column list - what does that mean?
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Thu Apr 11 07:16:30 PDT 2024
that's the errorMsg which is thrown if 'select * from table_name' does
not work. Looks like a wrong table name or bad connection-parameters.
Have you tried to connect the DB with sqldeveloper and with the same
user-credentials you use in your your mapfile?
Jörg
Am 11.04.24 um 14:56 schrieb Gerhard Völkl via MapServer-users:
> Hello,
> what does that error message mean „ msOracleSpatialLayerGetItems():
> Query error. Cannot retrieve column list“?
> Thanks
> Best regards Gerhard
> Von meinem iPad gesendet
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter:http://twitter.com/WhereGroup_com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240411/5c510f19/attachment.htm>
More information about the MapServer-users
