[MapServer-users] Mapserver>=8.0: Layer Composite Opacity
GOGIS Dieter Zuberbühler dieter.zuberbuehler at gogis.ch
Wed Aug 7 05:53:56 PDT 2024
What happend to the 'Layer Composite Opacity' in Mapserver>=8.0? I
tried several versions of Mapserver 8.x on Ubuntu 22.04 and 24.04 and
had always the same result: 'Opacity on Layer Level' is ignored and the
background layers are not visible.
I tried with map2img and phpng (swig), same result.
In the documentation it is still available and the mapfile is parsed
correctly. I can get and set the opacity with php and it will be
written down (save to mapfile) correctly.
Any hint, is this removed or a known problem?
Thank you in advance,
Dieter
GOGIS GmbH
Rosenstrasse 2
CH-4142 Münchenstein
More information about the MapServer-users mailing list
