[MapServer-users] Mapserver>=8.0 problem when using FILTER in getmap with CLASS with MINSCALEDENOM/MAXSCALEDENOM
Oliver Christen oliver.christen at camptocamp.com
Wed Aug 14 05:09:20 PDT 2024
Hello
I recently upgraded Mapser from 7.6 to 8.0 in a project and I'm observing
some weird behavior when specifying a FILTER= parameter in the GetMap
request when the target layer has multiple CLASS with
different MINSCALEDENOM/MAXSCALEDENOM.
With 7.6, Mapserver was using the correct CLASS respecting the
With 8.0, Mapserver ignores the MINSCALEDENOM/MAXSCALEDENOM and renders the
layer using the first CLASS defined in the layer.
I searched if this problem has been reported before but I couldn't find
anything,
is this a known regression ?
If yes can you point me to the related issue ?
If not, I will try to create a testcase to join to a new issue.
Thank you
Oliver Christen
<https://www.camptocamp.com/en/news-events/camptocamp-flagship-office-bussigny>
New address from 1st September 2022
Camptocamp SA
Route de la Chaux 4
1030 Bussigny
Suisse
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240814/67e42d11/attachment.htm>
More information about the MapServer-users mailing list
