[MapServer-users] Ogc api Limited
Malta e Sousa Stéphane Stephane.MaltaeSousa at ne.ch
Fri Aug 30 02:04:53 PDT 2024
Hi Gerhard,
You can set oga_max_limit to the limit you want in the layer metadata. For instance:
LAYER
    NAME "fo20_desserte"
    METADATA
        "ows_title" "FO20 - Desserte forestière"
        "oga_max_limit" "20000"
Best,
Stéphane Malta e Sousa
Responsable de projet et développement
https://sitn.ne.ch
-----Message d'origine-----
De : MapServer-users <mapserver-users-bounces at lists.osgeo.org> De la part de G. Völkl via MapServer-users
Envoyé : vendredi, 30 août 2024 10:54
À : MapServer Users <mapserver-users at lists.osgeo.org>
Objet : [MapServer-users] Ogc api Limited
[E-MAIL EXTERNE]
Hello,
When I’m using OGC feature API the respons is always limited to about ten items. What should I do if I want all items as default?
I do not use the limit attribut.
Thanks
Best regards, Gerhard
Von meinem iPhone gesendet
MapServer-users mailing list
MapServer-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
