[MapServer-users] XYZ file based layer shifted 180° East
Stefan Gofferje
lists at home.gofferje.net
Mon Jul 29 00:16:35 PDT 2024
Good morning!
On 7/29/24 10:02, Jaques Tati via MapServer-users wrote:
> there is not much detail about the version of MapServer you're using.
Apologies! I'm using docker camptocamp/mapserver:latest-arm64 which I
believe is MS 8.0.2 at the moment.
> With the current version we also had a problem with shifting outputs.
> Debugging revealed, that MapServer had a problem with the transformation
> of the input coordinates of the application. We are using the
> gisinternals distribution of MS8 binaries and since the current MS
> version uses proj9 to deal with different CRSs i was able to solve our
> problem with simply copying the file "epsg" from the directory
> /proj/shared to the /proj9/shared directory.
> Maybe you can give it a try.
Let's see if/how I can make this work with docker. Thanks for your input!
-Stefan
(o_ Stefan Gofferje | SCLT, MCP, CCSA
//\ Reg'd Linux User #247167 | VCP #2263
V_/_ https://www.gofferje.net | https://www.saakeskus.fi
More information about the MapServer-users
