[MapServer-users] Getting msCGILoadMap(): Web application error. Required configuration value MS_MAP_PATTERN not set.
Seth G sethg at geographika.co.uk
Wed Jun 5 14:35:51 PDT 2024
Try setting MAPSERVER_CONFIG_FILE to point to a mapserver.conf in your own Dockerfile and setting MS_MAP_PATTERN in this config file.
Without seeing your custom Dockerfile it is hard to know what could be removing an environment variable - it is simpler to control things with a config file.
If you check the /tmp/init_env file you should see the variables that are passed to the Apache environment (which is different from the system environment). If you override the default CMD ["/usr/local/bin/start-server"] then these env variables won't be set.
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Wed, Jun 5, 2024, at 9:21 PM, Rob Dennett wrote:
> Not sure how uncommenting something in the conf from camptocamp would help when we're actually setting MS_MAP_PATTERN in our Dockerfile which relies on the camptocamp one as a base image.  I created a github issue for this as well and they advised running
> Docker run <image> env | grep MS_
> And I see MS_MAP_PATTERN defined there along with MS_MAPFILE set to what I am expecting.  Wouldn't this prove that the environment variables are set correctly?
> *From:* Seth G <sethg at geographika.co.uk>
> *Sent:* Tuesday, June 4, 2024 4:32 PM
> *To:* Rob Dennett <Rob.Dennett at twdb.texas.gov>; MapServer Users <mapserver-users at lists.osgeo.org>
> *Cc:* Chris Repka <Chris.Repka at twdb.texas.gov>
> *Subject:* Re: [MapServer-users] Getting msCGILoadMap(): Web application error. Required configuration value MS_MAP_PATTERN not set.
> *External: Beware of links/attachments.*
> Hi Rob,
> You could try uncommenting the MS_MAP_PATTERN in the mapserver.conf [1] file on your Docker image to see if that has an effect.
> You should also see a log file named /tmp/init_env that lists all the environment variables used by Apache (including MS_MAP_PATTERN), similar to below:
> export "MAPSERVER_CONFIG_FILE=/etc/mapserver/mapfiles/mapserver.conf"
> export "MAPSERVER_CATCH_SEGV=1"
> export "HOSTNAME=mapserver"
> export "APACHE_CONFDIR=/etc/apache2"
> export "BUSY_TIMEOUT=300"
> export "MS_ERRORFILE=mapserver-8.0.log"
> export "PWD=/etc/mapserver"
> export "IO_TIMEOUT=40"
> export "HOME=/root"
> export "APACHE_LOG_DIR=/var/log/apache2"
> export "MIN_PROCESSES=1"
> export "APACHE_PID_FILE=/tmp/apache2/apache2.pid"
> export "MS_MAP_PATTERN=^\/etc\/mapserver\/([^\.][-_A-Za-z0-9\.]+\/{1})*([-_A-Za-z0-9\.]+\.map)$"
> Seth
> [1] https://github.com/camptocamp/docker-mapserver/blob/cffc18f12146969ed914834b7eba4b798e9c24d9/runtime/etc/mapserver.conf#L15
> [2] https://github.com/camptocamp/docker-mapserver/blob/31594debf18f091ad7ca5cf7126723bc014d9781/runtime/usr/local/bin/start-server#L8
> On Tue, Jun 4, 2024, at 11:08 PM, Rob Dennett via MapServer-users wrote:
>> We're using the camptocamp MapServer image and I just tried changing the base image from 7.6 to 8.0, i.e.
>> FROM camptocamp/mapserver:7.6
>> To
>> FROM camptocamp/mapserver:8.0
>> in our own Dockerfile and when I try to deploy, We're seeing
>> "msCGILoadMap(): Web application error.  Required configuration value MS_MAP_PATTERN not set."
>> on some endpoints (the ones ending in .map)
>> The camptocamp image contains
>> ENV MS_MAP_PATTERN=^\\/etc\\/mapserver\\/([^\\.][-_A-Za-z0-9\\.]+\\/{1})*([-_A-Za-z0-9\\.]+\\.map)$
>> (https://github.com/camptocamp/docker-mapserver/blob/8.0.0/Dockerfile#L85)
>> and our own overwrites this env var anyway, along with MS_MAPFILE
>> These haven't changed and they work fine as long as the base image is 7.6. The changelog mentions MS_MAPFILE, but as mentioned, we do define it.
>> (https://github.com/camptocamp/docker-mapserver/blob/8.0.0/README.md#changelog)
>> Any idea what might be happening?
 <https://github.com/camptocamp/docker-mapserver/blob/8.0.0/Dockerfile#L85>
>> docker-mapserver/Dockerfile at 8.0.0 · camptocamp/docker-mapserver <https://github.com/camptocamp/docker-mapserver/blob/8.0.0/Dockerfile#L85>
>> https://hub.docker.com/r/camptocamp/mapserver/. Contribute to camptocamp/docker-mapserver development by creating an account on GitHub.
>> github.com
>> github.com
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240605/53a99079/attachment.htm>
More information about the MapServer-users mailing list
