[MapServer-users] TIME dimension as runtime substitution within DATA query?
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Thu Jun 20 04:19:28 PDT 2024
What does not work for you in the WMS-T support as documented in WMS Time - MapServer 8.0.2 documentation<https://mapserver.org/ogc/wms_time.html>?
-Jukka Rahkonen-
Lähettäjä: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Marcin Niemyjski via MapServer-users
Lähetetty: torstai 20. kesäkuuta 2024 13.49
Vastaanottaja: Marcin Niemyjski via MapServer-users <mapserver-users at lists.osgeo.org>
Aihe: [MapServer-users] TIME dimension as runtime substitution within DATA query?
Hello
Is it possible to use the TIME dimension as a parameter for runtime substitution?
What I'm trying to achieve: I want to limit the rows in the database query by applying a date within the query itself. Specifically, I need to use the TIME dimension instead of custom parameters like start_date and stop_date to ensure full compatibility with the OGC WMS-T standard.
There is also the issue of parsing the TIME value into a format acceptable by the query. However, for now, let's assume that I'm providing a single date within TIME.
LAYER
DEBUG 5
STATUS OFF
NAME "stac_query"
TYPE POLYGON
CONNECTIONTYPE postgis
CONNECTION "***"
DATA "geometry from ... WHERE datetime >= %TIME% AND datetime <%TIME% AND (id = ANY ('{%pid%}') or '%pid%' = '-1' AND collection = ANY ('{cryo-demo}') ) ORDER BY datetime DESC, id DESC) as subquerry using unique id using srid=4326"
PROJECTION
"init=epsg:4326"
END
VALIDATION
'pid' '^.{2,37}$'
'asset' '^.{3,6}$'
'default_pid' '-1'
'default_asset' '-1'
END
METADATA
"wms_srs" "EPSG:3857 EPSG:4326 EPSG:2180"
"wms_title" "stac_query"
"wms_timeextent" "2015-01-01/2025-01-01/P1D"
"wms_timeitem" "datetime"
"wms_timedefault" "2024-04-08"
"wms_enable_request" "!*"
END
PROCESSING "CLOSE_CONNECTION=DEFER"
END
Any clue?
Best,
Marcin
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240620/750bc604/attachment.htm>
More information about the MapServer-users
