[MapServer-users] Missing blank in SQL
Seth G
sethg at geographika.co.uk
Wed Jun 26 04:19:27 PDT 2024
I'm presuming this is using the Oracle driver looking at the error message?
Probably unrelated, but isn't your DATA clause missing a USING?
DATA "GEOM FROM TEST_TABLE using unique objid_parent USING SRID 25832"
https://mapserver.org/input/vector/oracle.html#example-of-a-layer
I remember the DATA clause when logged was missing spaces in the MSSQL driver, but the actual SQL sent to the database was fine - you can check this with a SQL profiler.
You can also try the following syntax:
DATA "GEOM FROM (SELECT * FROM TEST_TABLE) AS tbl USING UNIQUE ObjectId USING SRID=25832"
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Wed, Jun 26, 2024, at 12:16 PM, G. Völkl via MapServer-users wrote:
> Hello
>> In the map file is this statement
>> DATA "GEOM FROM TEST_TABLE using unique objid_parent SRID 25832"
>> I get this message from mapserver in log file
>> Error: ORA-00907: missing right parentesis
>> . Query statement: SELECT SDO_AGGR_MBR(GEOM) AS GEOM from (SELECTGEOM FROM test_table)
>> This have to be changed SELECTGEOM to select geom
>> Can I do something in the map file or is it a bug?
> Best regards Gerhard
> Von meinem iPhone gesendet
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240626/ae994d4e/attachment.htm>
More information about the MapServer-users
