[MapServer-users] 'application/json' is not a permitted output format for layer
Yves Jacolin yves.jacolin at camptocamp.com
Thu Mar 28 02:07:16 PDT 2024
I will test and will tell you. I was pretty sure to check such metadata
before :)
Thanks for your quick reply Mathias.
Y.
Le jeu. 28 mars 2024 à 09:40, mathias cunault <mathias.cunault at inrap.fr> a
écrit :
> Hello,
> With your OUTPUTFORMAT configuration, if you want to use application/json
> in the URL of the WFS, verify that the wfs_getfeature_formatlist METADATA
> of your layer contains application/json.
> It is my configuration and it works fine. I hope it helps.
> Le jeu. 28 mars 2024 à 09:00, Yves Jacolin via MapServer-users <
> mapserver-users at lists.osgeo.org> a écrit :
>> Hello,
>> I have a mapserver WFS service running for some time without any issue.
>> We upgraded to 7.6.5 and now a WFS request
>> with OUTPUTFORMAT=application/json; subtype=geojson; charset=utf-8 failed
>> with this message: msWFSGetFeature(): WFS server error. 'application/json'
>> is not a permitted output format for layer 'XXXXX', review
>> wfs_getfeature_formatlist setting.
>> The mapfile looks like:
>>     OUTPUTFORMAT
>>         NAME "geojson"
>>         DRIVER "OGR/GEOJSON"
>>         MIMETYPE "application/json; subtype=geojson; charset=utf-8"
>>         FORMATOPTION "STORAGE=stream"
>>         FORMATOPTION "FORM=SIMPLE"
>>     EN
>> If I use outputformat=geojson it works. Is it normal? Do you think that
>> Ican change the outputformat name to "application/json; subtype=geojson;
>> charset=utf-8"
>> Thanks,
>> Y.
>> [image: This is Yves Jacolin's card. Their email is
>> yves.jacolin at camptocamp.com. Their phone number is +33 6 18 75 42 21. Their
>> phone number is +33 4 58 48 20 43. Their phone number is +41 21 619 10 43.]
>> <https://hihello.me/p/c7a536d1-5177-4817-8924-ebb067e58d4f>
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240328/6b003c40/attachment.htm>
More information about the MapServer-users mailing list
