[MapServer-users] CGI variable "map" fails to validate
Lernout, Matthew Matt.Lernout at stantec.com
Wed Mar 6 14:58:40 PST 2024
I think I've stumbled into what is causing my issue.
I was making requests to the endpoint /cgi-bin/mapserv.exe? (which is what I used in 7.6.2)
When I change request to the endpoint /cgi-bin/? (no mapserv.exe) my requests work and validate as expected.
I'm not sure why this is the case - if I swap my FastCGI back to point to the 7.6.2 module it serves requests at /mapserv.exe, but with 8.0.1 including the executable as part of the path causes issues with map validation.
In any case, I can work around this by updating all the web apps to point to the new path (maybe also add in a URL Rewrite).
Thanks,
Matt
-----Original Message-----
From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> On Behalf Of Lernout, Matthew via MapServer-users
Sent: Wednesday, March 6, 2024 5:29 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [MapServer-users] CGI variable "map" fails to validate
So, still banging my head against this a month later after eliminating HTTPS as the bogeyman.
Using FastCGI and MapServer with the simplest config and what should be an "allow everything" test expression:
CONFIG
  ENV
           MS_MAP_PATTERN "."
  END
END
And all requests return:
msLoadMap(): Regular expression error. Filename validation failed.
BONUS: If I strip out the map variable from my request, I'd expect the error "CGI variable "map" is not set." but I still get "msLoadMap(): Regular expression error. Filename validation failed." even without providing a map! This is following IISRESET, and I know the config is being loaded (if I remove it, I get "msLoadConfig(): Unable to access file")
If I'm not supplying a map parameter in my request and it's not throwing an error that it's missing, what is being used for map value against the expression? (And how do I get it to read my variable in the request?)
Thanks for any direction,
Matt
Sent: Wednesday, February 7, 2024 3:32 PM
After scratching my head for a while, realized all my testing was over HTTPS. Made a localhost connection over HTTP and the map variable was then valid.
I was looking in the wrong place - the error reports a failed validation, but that's due to failed certificate trust from what I can see.
Thanks for helping me steer into the real issue - I now have a direction to move in!
Matt
From: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Sent: Wednesday, February 7, 2024 1:05 PM
To: Lernout, Matthew <Matt.Lernout at stantec.com>; mapserver-users at lists.osgeo.org
[You don't often get email from jukka.rahkonen at maanmittauslaitos.fi. Learn why this is important at https://aka.ms/LearnAboutSenderIdentification ]
"." works for me.
I have a Windows env set first as
set MAPSERVER_CONFIG_FILE=\ms4w\ms4w.conf
These are the meaningful lines in the "ms4w.conf" file.
CONFIG
  ENV
           MS_MAP_PATTERN "."
  END
END
Test proves that validation is successful
http://localhost:8060/cgi-bin/mapserv.exe?map=f:\IMS_Maps\Client\projectarea.map
msLoadMap(): Unable to access file. (f:\IMS_Maps\Client\projectarea.map)
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Lernout, Matthew via MapServer-users
Lähetetty: keskiviikko 7. helmikuuta 2024 19.01
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: Re: [MapServer-users] CGI variable "map" fails to validate
I've ensured I am restarting the mapserv process with each config change - a quick test of commenting out the MS_MAP_PATTERN variable confirmed that is enough to refresh the config via error.
Here's a snippet of a sample request. It works with my running instance of Mapserver 7.6.2 but doesn't pass validation (pattern '.') in MapServer 8.0.1.
Matt
Sent: Wednesday, February 7, 2024 11:48 AM
To: Lernout, Matthew <Matt.Lernout at stantec.com>; MapServer Users <mapserver-users at lists.osgeo.org>
[You don't often get email from sethg at geographika.co.uk. Learn why this is important at https://aka.ms/LearnAboutSenderIdentification ]
Hi Matthew,
The CONFIG file I think is only reloaded when IIS or the Application Pool is restarted, so some changes to the regex may have been ignored.
Do you have a sample request with the &map= parameter? Is there anything in a web.config file that could be stripping these out or modifying them?
Seth
web:https://geographika.net/ & https://mapserverstudio.net/
twitter: @geographika
On Wed, Feb 7, 2024, at 5:33 PM, Lernout, Matthew via MapServer-users wrote:
> MS_MAP_PATTERN '.' also results in the same failed validation error,
> which is what makes me think the issue may be with another config
> setting. '.' should match any input, right?
> Just to make sure my config file was being loaded, I commented out the
> MS_MAP_PATTERN entry entirely, and got the error "msCGILoadMap(): Web
> application error. Required configuration value MS_MAP_PATTERN not set."
> Matt
> Behalf Of Jörg Thomsen (WhereGroup) via MapServer-users
> Sent: Wednesday, February 7, 2024 3:24 AM
> [You don't often get email from mapserver-users at lists.osgeo.org. Learn
> Hi,
> I'm not sure whether the pattern is correct. Shouldn't ist start with ^?
> Have yout tried
> MS_MAP_PATTERN '.'? (not for production, just as a test)
> Jörg
> Am 06.02.24 um 20:12 schrieb Lernout, Matthew via MapServer-users:
>> Hi,
>> Having trouble making requests since updating to 8.0.1 from 7.6.2.
>> Mapserver is running in IIS using FastCGI and the configuration steps
>> from:
>> https://maps/
>> erver.org%2Finstallation%2Fiis.html&data=05%7C02%7Cmatt.lernout%40sta
>> n
>> tec.com%7C34322cf56ae745f61ae908dc27b617c5%7C413c6f2c219a469297d3f2b4
>> d
>> 80281e7%7C0%7C0%7C638428910243090792%7CUnknown%7CTWFpbGZsb3d8eyJWIjoi
>> M
>> C4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7
>> C
>> &sdata=dh%2BpgGwk5996f0GEMeX7O8rcv5J81TnPzeFNZ9XoVLs%3D&reserved=0
>> <https://map/
>> server.org%2Finstallation%2Fiis.html&data=05%7C02%7Cmatt.lernout%40st
>> a
>> ntec.com%7C34322cf56ae745f61ae908dc27b617c5%7C413c6f2c219a469297d3f2b
>> 4
>> d80281e7%7C0%7C0%7C638428910243098246%7CUnknown%7CTWFpbGZsb3d8eyJWIjo
>> i
>> MC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%
>> 7
>> C&sdata=OIoWHSlKZJrXWspqwVfY5jhX4lzBcQuI%2Bw5IeOVtXBA%3D&reserved=0>
>> A new config file was added to the filesystem and server Environment
>> variables as per documented requirements added since 7.6.3, but
>> having trouble validating any map arguments. All requests return the
>> error "CGI variable "map" fails to validate" even though regexp
>> should pass based on expression tests.
>> Here is the full config file in use:
>> CONFIG
>>    ENV
>>      MS_MAP_PATTERN "\.map$"
>>      PROJ_LIB "F:/MapServer/bin/proj7/SHARE"
>>      CURL_CA_BUNDLE "F:\MapServer\bin\curl\curl-ca-bundle.crt"
>>    END
>>    PLUGINS
>>      "mssql" "F:/MapServer/bin/ms/plugins/mssql2008/msplugin_mssql2008.dll"
>>      "oci" "F:/MapServer/bin/ms/plugins/oci/msplugin_oracle.dll"
>>    END
>> END
>> The current MS_MAP_PATTERN is just a simplified test to confirm 8.0.1
>> working before I update to the real regexp, and my understanding is
>> it should map anything that ends in .map? But every map argument I
>> throw in (including verified working arguments for 7.6.2) result in a
>> failure to validate. Are there other crucial configurations missing
>> that are necessary to pass validation?
>> Thanks,
>> Matt
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://list/
>> s.osgeo.org%2Fmailman%2Flistinfo%2Fmapserver-users&data=05%7C02%7Cmat
>> t
>> .lernout%40stantec.com%7C34322cf56ae745f61ae908dc27b617c5%7C413c6f2c2
>> 1
>> 9a469297d3f2b4d80281e7%7C0%7C0%7C638428910243105153%7CUnknown%7CTWFpb
>> G
>> Zsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0
>> 3D%7C0%7C%7C%7C&sdata=c%2BjBl2NTy%2BIZxCYZmp0CLwa2ujlD%2BC%2BfzzIQgXK
>> w
>> lyI%3D&reserved=0
> Viele Grüße,
> Jörg Thomsen
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der
> http://www.f/
> %2F&data=05%7C02%7Cmatt.lernout%40stantec.com%7Ca6a54b2be1934039867008
> dc3e2cf378%7C413c6f2c219a469297d3f2b4d80281e7%7C0%7C0%7C63845360999762
> 1174%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBT
> iI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=J3mMHQjcPmraEul%2FQpVahH9
> UvtbauvXXMtXUiO1ymkk%3D&reserved=0
> %2F&data=05%7C02%7Cmatt.lernout%40stantec.com%7C3da097b4c8f14244081908
> dc281be563%7C413c6f2c219a469297d3f2b4d80281e7%7C0%7C0%7C63842934748763
> 9638%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBT
> iI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=sT3uaBmTuH%2FjMMYbOuD4f5n
> VIByhR%2FX3FkSA5a1oz7U%3D&reserved=0
> %2F&data=05%7C02%7CMatt.Lernout%40stantec.com%7C10165ecd716b4149010108
> dc28075d52%7C413c6f2c219a469297d3f2b4d80281e7%7C0%7C0%7C63842925930776
> 7073%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBT
> iI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=c%2F6yf3KoD736puorBam%2BF
> h0CPIvAZHeM9JE%2BaLLh40A%3D&reserved=0
> %2F&data=05%7C02%7Cjukka.rahkonen%40maanmittauslaitos.fi%7Cb1ac588f3ea
> 94378069c08dc27fe5c36%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C638
> 429220639531250%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2
> luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=6DJDUpY4WQcsCQ
> c95tGoKBRTx9Ff8naSFezd%2FDbuM7s%3D&reserved=0
> oss-academy.com%2F&data=05%7C02%7CMatt.Lernout%40stantec.com%7C6bfc803
> 339354908ddc508dc27fca7b1%7C413c6f2c219a469297d3f2b4d80281e7%7C0%7C0%7
> C638429213306207068%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIj
> oiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=N3W9lnwc3z
> oNjXmUW993zzswV1YBXAED99N2OoI615g%3D&reserved=0
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Tel: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> joerg.thomsen at wheregroup.com
> http://www.w/
> 5396%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBT
> iI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=kk66wDIowDxRGYb1CmX1lxBJs
> BMdphU0G9KK9aGF%2F2Q%3D&reserved=0
> dc281be563%7C413c6f2c219a469297d3f2b4d80281e7%7C0%7C0%7C63842934748764
> 3827%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBT
> iI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=OXSC01x1nY3zMWxCZASry4yRR
> p%2FFcZMQlZaZ2%2FyA0To%3D&reserved=0
> dc28075d52%7C413c6f2c219a469297d3f2b4d80281e7%7C0%7C0%7C63842925930777
> 1350%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBT
> iI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=%2Bsjgvauyi7OelgrSWhkxILz
> 2UenzLzP4UCdinOXxVKs%3D&reserved=0
> 429220639536742%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2
> luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=GHmLgYpKwyBx4J
> BxoERE3BKI6Oll7uYA%2BJoV5Fp3VFU%3D&reserved=0
> heregroup.com%2F&data=05%7C02%7CMatt.Lernout%40stantec.com%7C6bfc80333
> 9354908ddc508dc27fca7b1%7C413c6f2c219a469297d3f2b4d80281e7%7C0%7C0%7C6
> 38429213306211969%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoi
> V2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=2eHjEWZMX%2B
> r5Ciu10Erm5j6rVD%2BOWyIbwBtePd2gDJ8%3D&reserved=0
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter:
> http://twitt/
> er.com%2FWhereGroup_com&data=05%7C02%7CMatt.Lernout%40stantec.com%7C6b
> fc803339354908ddc508dc27fca7b1%7C413c6f2c219a469297d3f2b4d80281e7%7C0%
> 7C0%7C638429213306217142%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiL
> CJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=nIup%
> 2BinkBHUNOhGb4s5sM8IrV58Ar5t%2B5NRsAkZDzkc%3D&reserved=0
> https://list/
> s.osgeo.org%2Fmailman%2Flistinfo%2Fmapserver-users&data=05%7C02%7CMatt
> .Lernout%40stantec.com%7C6bfc803339354908ddc508dc27fca7b1%7C413c6f2c21
> 9a469297d3f2b4d80281e7%7C0%7C0%7C638429213306222189%7CUnknown%7CTWFpbG
> Zsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%
> 3D%7C0%7C%7C%7C&sdata=T9CIsI3SiBLp%2BDt9jsu9Q9%2FNVmUd1hCtEgoOgYtzdt8%
> 3D&reserved=0
>  Caution: This email originated from outside of Stantec. Please take
> extra precaution.
>  Attention: Ce courriel provient de l'extérieur de Stantec. Veuillez
> prendre des précautions supplémentaires.
>  Atención: Este correo electrónico proviene de fuera de Stantec. Por
> favor, tome precauciones adicionales.
> https://list/
> 9a469297d3f2b4d80281e7%7C0%7C0%7C638429213306226943%7CUnknown%7CTWFpbG
> 3D%7C0%7C%7C%7C&sdata=fxiaaf1f3%2F2cUrMl%2BBjIRBi8BDPaL8Tzyd3L9qPQMdA%
> 3D&reserved=0
 Caution: This email originated from outside of Stantec. Please take extra precaution.
 Attention: Ce courriel provient de l'extérieur de Stantec. Veuillez prendre des précautions supplémentaires.
 Atención: Este correo electrónico proviene de fuera de Stantec. Por favor, tome precauciones adicionales.
https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
