[MapServer-users] zoomRectangle error image rectangle maxy >= miny
Fernando Sánchez García nando_gcia at hotmail.com
Wed May 8 00:53:27 PDT 2024
Thanks for everything Seth, it's already solved. The truth is that I had
previously tried reversing the values of Y but the result was another error:
$pixext = new rectObj($minx, $miny, $maxx, $maxy);
"Error: rectObj(): Invalid rectangle. { 'minx': 596.000000 , 'miny':
85.000000 , 'maxx': 745.000000 , 'maxy': 50.000000 }"
and it is because the fifth argument "imageunits" of the rectObj
function is not optional (as written in the documentation at
https://mapserver.org/mapscript/mapscript-api/stub/mapscript.rectObj.html),
but which is mandatory.
$pixext = new rectObj($minx, $miny, $maxx, $maxy, 1);
"Zoom completed successfully."
Best regards.
El 07/05/2024 a las 16:40, Seth G escribió:
> Hi Fernando,
> There is a test case for this at:
> https://github.com/MapServer/MapServer/blob/0cb56232d4ca0e64d747efa1db602ff08e0ea42f/src/mapscript/python/tests/cases/zoom_test.py#L99
> This test has the MaxY < MinY. It looks like the rectObj represents an image rather than a map, and so the maxy and miny need to be reversed as in your original PHP code for SWIG MapScript too.
> The error message is:
>> Exception: mapscript::mapObj::zoomRectangle(): General error message.
>> image rectangle maxy >= miny in
> And is raised athttps://github.com/MapServer/MapServer/blob/0cb56232d4ca0e64d747efa1db602ff08e0ea42f/src/mapscript/swiginc/mapzoom.i#L239
> There is a comment in the source code where this error is thrown (I think it applies to maxy too):
>          /* This is not a typo: "maxx >= minx". For historical reason, we
>           * keep this as it is. See documentation for more info about this check. */
>          if (poPixRect->maxy >= poPixRect->miny) {
>              msSetError(MS_MISCERR, "image rectangle maxy >= miny", "mapscript::mapObj::zoomRectangle()");
>              return MS_FAILURE;
> Seehttps://github.com/MapServer/MapServer/issues/3286
> So you'll need to reverse the Y values below (likely as it did in the old code). The API docs should also include this note.
>> $this->geoext0->minx -334.31761006289
>> $this->geoext0->miny -22
>> $this->geoext0->maxx 525.31761006289
>> $this->geoext0->maxy 342
> Seth
> web:https://geographika.net  &https://mapserverstudio.net
> twitter: @geographika
> On Tue, May 7, 2024, at 10:43 AM, Fernando Sánchez García via MapServer-users wrote:
>> Dear users, my name is Fernando and I work at the University of Córdoba
>> in Spain. I have been using mapserver for several years as a user at the
>> University together with pmapper. Our old virtual machine has Ubuntu
>> Server 18.04 LTS + mapserver 7.2.1 + PHP 5.6.40 + postgres/postgis with
>> pmapper 4.3.2. and locally on my computer I have MS4W 3.2.3 with pmapper
>> 4.3.2. Unfortunately pmapper was discontinued a few years ago and
>> although I don't have much programming knowledge, I have started trying
>> to make some small changes to the pmapper code to adapt it to PHP 7/8
>> (although I know other more up-to-date alternatives such as Openlayers).
>> I have reached the "Zoom to rectangle" function where Armin implemented
>> it like this:
>>        * ZOOM&PAN FUNCTIONS
>>        * Zoom to rectangle
>>       protected function pmap_zoomrect()
>>           if (isset($_REQUEST["imgbox"])) {
>>               $imgbox_str = $_REQUEST["imgbox"];
>>               //error_log($imgbox_str);
>>               if ($imgbox_str != "") {
>>                   $imgbox_arr = explode(" ", $imgbox_str);
>>                   // New map extent in image pixel ((0,0) top-left)
>>                   $pix_minx = $imgbox_arr[0];
>>                   $pix_miny = $imgbox_arr[1];
>>                   $pix_maxx = $imgbox_arr[2];
>>                   $pix_maxy = $imgbox_arr[3];
>>                   if ($pix_minx == $pix_maxx) $pix_maxx = $pix_maxx + 3;
>> ## increase max extent if min==max
>>                   if ($pix_miny == $pix_maxy) $pix_maxy = $pix_maxy - 3;  ##
>>                   $pixext = ms_newrectObj();
>>                   // Modified by Thomas RAFFIN (SIRAP)
>>                   // If the rectangle is not in the same proportions as
>> the map,
>>                   // To leave the coeff Y / X unghanged, we need to made
>> $geoNewCoeff = $geo0Coeff...
>>                   $geo0Coeff = $this->mapheight / $this->mapwidth;
>>                   $geoNewDeltaX = $pix_maxx - $pix_minx;
>>                   $geoNewDeltaY = $pix_maxy - $pix_miny;
>>                   $geoNewCoeff = $geoNewDeltaY / $geoNewDeltaX;
>>                   if ($geoNewCoeff < $geo0Coeff) {
>>                       $newDeltaYCorrected = $geo0Coeff * $geoNewDeltaX;
>>                       $newDeltaYToAdd = ($newDeltaYCorrected -
>> $geoNewDeltaY) / 2;
>>                       $pix_miny -= $newDeltaYToAdd;
>>                       $pix_maxy += $newDeltaYToAdd;
>>                   } else {
>>                       $newDeltaXCorrected = $geoNewDeltaY / $geo0Coeff;
>>                       $newDeltaXToAdd = ($newDeltaXCorrected -
>> $geoNewDeltaX) / 2;
>>                       $pix_minx -= $newDeltaXToAdd;
>>                       $pix_maxx += $newDeltaXToAdd;
>> $pixext->setExtent($pix_minx,$pix_miny,$pix_maxx,$pix_maxy);
>>           // Zoom to full extent when starting
>>           } else {
>>               $pixext->setExtent(0, 0, $this->mapwidth, $this->mapheight);
>>           $this->map->zoomrectangle($pixext, $this->mapwidth,
>> $this->mapheight, $this->geoext0);
>>           PMCommon::freeMsObj($pixext);
>> In this function Mapscript zoomrectangle is called, which according to
>> the old PHP Mapscript documentation
>> (https://mapserver.org/mapscript/php/index-5.6.html#mapobj) is like this:
>> void zoomrectangle(rectObj oPixelExt, int nImageWidth, int nImageHeight,
>> rectObj oGeorefExt)
>>       Set the map extents to a given extents.
>>       Parameters are :
>>               oPixelExt (rect object) : Pixel Extents, with (0,0) at the
>> top-left The rectangle contains the coordinates of the LL and UR
>> coordinates in pixel. (the maxy in the rect object should be < miny value)
>>               ------- UR (values in the rect object : maxx, maxy)
>>               LL (values in the rectobject minx, miny)
>>               Width : width in pixel of the current image.
>>               Height : Height in pixel of the current image.
>>               Georef extent (rectObj) : current georef extents.
>> The pmapper log file shows me the following values when I zoom without
>> any problem and the result is satisfactory, that is, it zooms in on my
>> map correctly:
>> P.MAPPER debug info en la función pmap_zoomrect de map.php
>> $pix_minx 551.97186827847
>> $pix_miny 86.08332824707031
>> $pix_maxx 632.19478821567
>> $pix_maxy 120.08332824707031
>> My .map file has the following EXTENT -37 -22 228 334 and "wms_srs"
>> "epsg:3857".
>> I have updated to MS4W 4.0.4 which has MapServer and MapScript
>> 7.7.0-dev, PHP to 7.2.31 and SWIG support. According to the current SWIG
>> MapScript API Reference:
>> mapscript.mapObj
>> class mapscript.mapObj(*args)
>> Methods:
>> zoomRectangle(poPixRect: rectObj, width: int, height: int, poGeorefExt:
>> rectObj, poMaxGeorefExt: rectObj) → int[source]
>>       Set the map extents to a given extents. Returns MS_SUCCESS or
>> MS_FAILURE on error
>> and I have adapted the code like this:
>>        * Zoom to rectangle
>>               pm_logDebug(3, $imgbox_str, "\$imgbox_str en la función
>> pmap_zoomrect de map.php");
>>               //  642.0833282470703 40.08332824707031 685.0833282470703
>> 68.08332824707031
>>                   // BEFORE:
>>                   // $pixext = ms_newrectObj();
>> the map,
>> $geoNewDeltaY) / 2;
>>                   } else {
>> $geoNewDeltaX) / 2;
>>                   // BEFORE:
>>                   // NEW:
>>                   $pixext = new rectObj($pix_minx, $pix_miny, $pix_maxx,
>> $pix_maxy);
>>           } else {
>>           // BEFORE:
>>           // $this->map->zoomrectangle($pixext, $this->mapwidth,
>>           // NEW:
>>           $maxGeoExt = null; // Null o tu valor predeterminado para la
>> extensión geográfica máxima
>>           $this->map->zoomRectangle($pixext, $this->mapwidth,
>> $this->mapheight, $this->geoext0, $maxGeoExt);
>> but the following error is returned:
>> [06-May-2024 12:49:32 Europe/Paris] PHP Fatal error:  Uncaught
>> C:\ms4w\apps\sig-uco\htdocs\phpmapscriptng-swig\include\mapscript.php:2908
>> Stack trace:
>> #0
>> C:\ms4w\apps\sig-uco\htdocs\phpmapscriptng-swig\include\mapscript.php(2908):
>> mapobj_zoomrectangle(Resource id #10, Object(rectObj), '1503.166666',
>> '351.16666599999...', Object(rectObj), NULL)
>> #1
>> C:\ms4w\apps\sig-uco\htdocs\pmapper\pmapper-4.3.2\incphp\map\map.php(629):
>> mapObj->zoomRectangle(Object(rectObj), '1503.166666',
>> #2
>> C:\ms4w\apps\sig-uco\htdocs\pmapper\pmapper-4.3.2\incphp\map\map.php(489):
>> PMap->pmap_zoomrect()
>> #3
>> C:\ms4w\apps\sig-uco\htdocs\pmapper\pmapper-4.3.2\incphp\map\map.php(74):
>> PMap->pmap_createMap()
>> #4
>> C:\ms4w\apps\sig-uco\htdocs\pmapper\pmapper-4.3.2\incphp\xajax\x_load.php(78):
>> PMap->pmap_create()
>> #5 {main}
>>     thrown in
>> C:\ms4w\apps\sig-uco\htdocs\phpmapscriptng-swig\include\mapscript.php on
>> line 2908
>> I have also updated to MS4W 5.0.0 which has MapServer and MapScript
>> 8.2.0-dev and PHP to 8.2.11 and the error is the same.
>> How should I solve the problem? Thanks.
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240508/bae4df2f/attachment.htm>
More information about the MapServer-users mailing list
