[MapServer-users] Up-to-date docker image for mapserver
Rob Dennett Rob.Dennett at twdb.texas.gov
Mon May 20 08:10:25 PDT 2024
I just created an issue in the repo since 8.0 is two years old at this point.  We already tried making our own fork, but are running into issues.  the latest was
ERROR: failed to solve: process "/bin/bash -o pipefail -cux if test \"${WITH_ORACLE}\" = \"ON\"; then       export ORACLE_HOME=/usr/local/lib;     fi;     cmake ..     -GNinja     -DCMAKE_C_FLAGS=\"-O2 -DPROJ_RENAME_SYMBOLS\"     -DCMAKE_CXX_FLAGS=\"-O2 -DPROJ_RENAME_SYMBOLS\"     -DCMAKE_BUILD_TYPE=Release     -DCMAKE_INSTALL_PREFIX=/usr/local     -DWITH_CLIENT_WMS=1     -DWITH_CLIENT_WFS=1     -DWITH_OGCAPI=1     -DWITH_KML=1     -DWITH_SOS=1     -DWITH_XMLMAPFILE=1     -DWITH_CAIRO=1     -DWITH_RSVG=1     -DUSE_PROJ=1     -DUSE_WFS_SVR=1     -DUSE_OGCAPI_SVR=1     -DWITH_ORACLESPATIAL=${WITH_ORACLE}" did not complete successfully: exit code: 1
Sent: Monday, May 20, 2024 5:03 AM
To: Rob Dennett <Rob.Dennett at twdb.texas.gov>; MapServer Users <mapserver-users at lists.osgeo.org>
Subject: Re: [MapServer-users] Up-to-date docker image for mapserver
External: Beware of links/attachments.
Hi Rob,
As far as I'm aware, the camptocamp Docker image is the best maintained public Docker image.
You could fork this and create a new Docker image with the updated Apache. I believe it would be a case of updating the versions in https://github.com/camptocamp/docker-mapserver/blob/master/ci/dpkg-versions.yaml (and the version being available).
You could also create an issue at https://github.com/camptocamp/docker-mapserver/issues detailing the security issues with the current version of Apache used.
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Fri, May 17, 2024, at 3:40 PM, Rob Dennett via MapServer-users wrote:
We're currently using a docker image from camptocamp (https://github.com/camptocamp/docker-mapserver) in an ECS service for our MapServer implementation.  However, the 7.6 tag version we're using, along with latest 8.0 tag and even the master bundle MapServer with Apache 2.4.52 at the latest.  The most recent version is 2.4.59 and we're trying to update it to resolve issues found in a pen test.  Is there a more recent Docker image that people are using?
Thanks,
Rob
MapServer-users mailing list
MapServer-users at lists.osgeo.org<mailto:MapServer-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240520/18c5e0fc/attachment.htm>
More information about the MapServer-users mailing list
